C5 Parts for Sale/Wanted C5 Corvette Performance Parts, Superchargers, Turbo Kits, Wheels & Tires, Exterior Enhancements, OEM, Aftermarket
WTB: Z51 rear sway bar.
Old 12-10-2018, 10:37 PM
Uassaide
Uassaide's Avatar
Default Z51 rear sway bar.
looking for a rear z51 sway bar.
Thanks
Uassaide is offline
Old 12-11-2018, 03:54 AM
Gitusum
Gitusum's Avatar
I have 1 $150 shipped
Gitusum is offline
Old 12-11-2018, 08:13 AM
Jake2002
Jake2002's Avatar
Default Front and rear sway bars 02 Z06
I have a set off 12000 miles car- $150+shipping
Jake2002 is offline
Old 12-11-2018, 09:38 AM
Uassaide
Uassaide's Avatar
what year is it from?
Uassaide is offline
Old 12-11-2018, 09:41 AM
Uassaide
Uassaide's Avatar
thank you but i have a c5z already, im looking to upgrade the rear sway with the z51
Uassaide is offline
Old 12-11-2018, 01:11 PM
Gitusum
Gitusum's Avatar
2000
Gitusum is offline
Old 12-18-2018, 07:24 PM
SLVRVERT
SLVRVERT's Avatar
Default Keep you posted.
I might be up grading my front and rear soon. I will have to see if the O Connells will clear my scavenging pump for my turbos. But they are from a C6 Z51 and are 31mm. The new ones are 35mm so I will do a test fit. If they dont fit I will have a set of new O Connells laying around. Should be here either before or shortly after Christmas.
SLVRVERT is offline
Old 12-18-2018, 07:37 PM
Uassaide
Uassaide's Avatar
awesome! Let me know so we can work something out
Uassaide is offline
Old 12-19-2018, 10:20 AM
JHrinsin
JHrinsin's Avatar
Okay sorry for being a bit ****, but which Z51 rear sway bar are you looking for?
'97-99 C5 Z51 21.7mm
'00-04 C5 Z51 23.6mm (same as the '01-04 Z06)
or the C6 Z51 25.6mm
Since you stated that you have a C5 Z06 and wanted to "upgrade", I would have to presume you are looking for a C6 Z51 25.6mm rear sway bar - correct?
JHrinsin is offline
Old 12-19-2018, 10:26 AM
Uassaide
Uassaide's Avatar
yes sorry, looking for a rear c6 z51 sway bar. & thanks for comparing the Sizes.
Uassaide is offline
Old 12-21-2018, 07:12 AM
SLVRVERT
SLVRVERT's Avatar
You are correct I was thinking the front sway bar size. Good call.
SLVRVERT is offline
Old 12-25-2018, 09:18 AM
cmjuhl
cmjuhl's Avatar
Thanks
I purchased front and rear sways from link below, everything looks great. Just need to install this spring.
https://www.gmoemautoparts.com/oem-p...SABEgKh4PD_BwE
Genuine GM C6Z51 Sway Bar
25919502 – Front stabilizer bar
10339124 – Rear stabilizer bar
10387838 – Front stabilizer bar bushings (2)
15241135 – Rear stabilizer bar bushings (2)
cmjuhl is offline
Old 12-25-2018, 11:28 AM
Uassaide
Uassaide's Avatar
Awesome thanks! I wonder if the brackets would remain the same?
Uassaide is offline
Old 12-25-2018, 01:01 PM
cmjuhl
cmjuhl's Avatar
I hope so i didn't order any!
From what I have read on line / corvette forum they should work just fine.
Might have to shim with metal plate or washers, metal plate sound like the best option, because the bushings have something to rest on.
https://www.corvetteforum.com/forums...bars-help.html
cmjuhl is offline
Old 12-25-2018, 07:58 PM
Uassaide
Uassaide's Avatar
thats good then, im just going to order the rear sway bar and then order some poly bushings
Uassaide is offline
Old 02-04-2019, 04:34 PM
sureready
sureready's Avatar
Thanks
I have a Z51 Sway bar I removed from my car for sale.
sureready is offline
To Z51 rear sway bar.
Quick Reply: WTB: Z51 rear sway bar.
