Permanent 2005 Column Lock Resolution from GM
Old 12-11-2018, 08:54 AM
LJD51
Support Corvetteforum!
LJD51's Avatar
Location: Eastern NC; Retired x 2 (US Army: 70-90 AD) (US Army: 91-16 DAC); yea, I'm old.
Default Permanent 2005 Column Lock Resolution from GM
ADMINS: Recommend this be a sticky on the C6 General Discussion and C6 Tech/Performance...
There is finally a permanent solution to end the column lock failures for 2005 manual transmission equipped cars. GM has issued a TSB (#18-NA-346, issued Nov 14, 2018) authorizing the complete disabling of the column lock system at the dealership. The TSB directs the removal of the locking plate, replacing it with a retaining plate and flashing the BCM to ignore the steering column lock module.
Too bad it took GM 13 years to come up with the TSB to permanently solve the column lock problem...I would still have my '05 if this had been available two years ago when I made the decision in Oct 2016 to trade mine after eight failures and having the dealer "fix" it time after time, only to fail again.
Even if you have not had a failure and/or installed the electronic bypass, I would have the TSB done.
Here is video describing the process:
Facebook Post
The following 8 users liked this post by LJD51:
Creedence85 (03-02-2021), jaredtxrx (12-11-2018), Kin Ton Ti (03-28-2019), Landru (12-11-2018), rc51racer (07-07-2019), sallen619 (12-12-2018), Shikaitsu (03-12-2019), ZR1Owner (06-14-2022) and 3 others liked this post. (Show less...)
Old 12-11-2018, 10:05 AM
WW7
WW7's Avatar
Yeah, like I'm going to trust a dealership to take my column apart and not screw anything else up on my car.. I think I will just leave the bypass in place, at least that works without any problems.. Now, if they want to replace the "rearend" with something stronger, I may go for that.....WW
Old 12-11-2018, 10:25 AM
LJD51
LJD51's Avatar
Have you had any failures?
Old 12-11-2018, 10:39 AM
WW7
WW7's Avatar
If you mean on the column lock, No, I installed the bypass before mine failed.. Didn't want to be stranded because of it failing.. If you mean on the rearend, yes, it was replaced, it failed while under warranty for the first owner.. If I lived near a dealership like "Kerbeck" or one of the other large dealerships I may have it done, but the smaller ones screw up more then they fix ..WW
Old 12-11-2018, 10:47 AM
LJD51
LJD51's Avatar
If you mean on the column lock, No, I installed the bypass before mine failed.. Didn't want to be stranded because of it failing.. If you mean on the rearend, yes, it was replaced, it failed while under warranty for the first owner..WW
Lucky you with no column lock failures; I was lucky that I never had any problems with the rear end; I even had 4.10's in mine for 75,000 miles with no problems...
At least you know there is a permanent solution if you have a column lock failure; just make sure you have it done at a dealership with a GM certified corvette tech.
Old 12-11-2018, 10:54 AM
WW7
WW7's Avatar
​​​​​​​That's what I was thinking, a large Corvette dealership would be the best bet... Thanks for posting the TSB.....WW
Old 12-11-2018, 11:01 AM
jaredtxrx
jaredtxrx's Avatar
!!!!!!!!!!!!!HOORAY!!!!!!!!!!!!!!!!
I think mine is starting to give up the ghost so I may in very soon for this fix.
Thanks LJD51 for the post!!
Old 12-11-2018, 12:11 PM
LJD51
LJD51's Avatar
Don't wait to be stranded or not able to drive it...
Old 12-11-2018, 12:49 PM
Racer1735
Racer1735's Avatar
Does GM handle TSB's the same as warranty, meaning covered by the manufacturer, or is this one on the consumer? I had the recall performed years ago on my 2005 manual C6, but and not occasionaly getting the Service Steering Column Lock warning on my DIC. When I do, I have to put the care back in to Reverse, turn off the ignition, and go thru the start process all over again.
Old 12-11-2018, 12:54 PM
LJD51
LJD51's Avatar
I don't know if a TSB is covered in the same as a warranty and I would check with the dealer. But it would be worth a couple of hundred $$$ to have the possible/probable failure removed. JMHO.
PS: make sure the dealer has a GM Certified Corvette Tech do the work...
Old 12-11-2018, 07:05 PM
cadyshac
cadyshac's Avatar
Owned my '05 for a little less than 2 years with no problems. From service records the column lock has never been an issue on my car either. I might get the is TSB done but not sure I trust taking it to a dealer.
Old 12-11-2018, 07:20 PM
LJD51
LJD51's Avatar
The dealer has to reprogram the BCM to ignore any signal from the steering column lock module.
Old 12-11-2018, 07:43 PM
cadyshac
cadyshac's Avatar
Sorry, yes I know the work would have to be done at a dealer. I am not crazy about the idea of them digging into the steering column is the issue. Do you know if the cost of this is covered by GM like a recall would be?
Old 12-11-2018, 08:03 PM
LJD51
LJD51's Avatar
i don’t know if GM covers the cost or not...if not, the cost should be much less than replacing the module itself.
As for digging into the steering column, I had to have my ‘05 repaired eight times with no problem...if I can remove the airbag, steering wheel, clock spring, locking plate and then everything works fine after put it back together, the dealer should be able to remove everything to install the new thingamabob with no problem.
cadyshac (12-12-2018)
Old 12-12-2018, 01:59 PM
jaredtxrx
jaredtxrx's Avatar
I have an appointment with a local dealer's "Corvette Specialist" Tuesday the 18th. I will try to remember to report back my findings.
The following 5 users liked this post by jaredtxrx:
cadyshac (12-12-2018), Dutch08 (12-12-2018), LJD51 (12-12-2018), Racer1735 (12-12-2018), VolSince69 (12-14-2018)
Old 12-12-2018, 11:44 PM
Jon05vette
Jon05vette's Avatar
2016 C6 of the Year Finalist
It is my understanding that this TSB is paid for by the car owner.
I will I’ll be having tis mod installed as soon as the parts come in.
Old 12-12-2018, 11:49 PM
LJD51
LJD51's Avatar
Originally Posted by jon05vette
it is my understanding that this tsb is paid for n the car owner.
I will i’ll be having tis mod installed as soon as the parts come in.
To Permanent 2005 Column Lock Resolution from GM
Old 12-17-2018, 10:19 PM
Jon05vette
Jon05vette's Avatar
I picked up the parts for this TSB today and discussed the labor with my local Chevy dealer today. They want to charge me $600 in labor and suggest I drop the car off for a full day or more. They were not sure they could complete the modification in a day. They have one Corvette specialist.
Really!!! I guess they have no work standard for this yet.
im going out for more estimates since I seem to have temporarily fixed the problem and can wait this out for a while.
Old 12-18-2018, 07:26 AM
cadyshac
cadyshac's Avatar
I am going to try to call a couple dealers in the Cincy area today and see if they know anything about this TSB and/or can quote a price to install. I will post what I find out about this too.
Old 12-18-2018, 08:47 AM
LJD51
LJD51's Avatar
Did you contact Criswell Chevrolet? They are the largest Corvette dealer in Greater DC area (I used to live in NOVA).
Quick Reply: Permanent 2005 Column Lock Resolution from GM
