Maintaining this "look" but with better grip
So I'm picking up a set of Forgeline F14 rims essentially mirroring this look:
https://www.corvetteforum.com/forums...-corvette.html
I'm aiming for a little more contact patch than what they have on the fronts as 275/35/18. I *think* the 305 in the rear should be enough. The rims haven't yet been ordered but will be within the next day. The front rim is 18x9.5 and I don't think it will accept a 295/30 tire. I think it has to be 18x10 for that. I'm really just trying to go with the most rubber on the road for better grip in the twisties while maintaining that look. Those rims are made to order at 1700 and I simply don't want to risk messing with those sizes too much then they look off and be stuck with them. I know those ones in the pictures are good. What would you guys suggest on an otherwise stock C5z for the twisties? Spirited driving and the occasional track day. I'll be running Toyo Proxes R888R FWIW.
Why not order 18x10 or 18x11 wheels ? You seem to want front rubber and handling so why 9.5 on a Z? The “look” does not change with width if correct offset!
The Forgestar F14 seem to be the common choice for many Corvette owners to do the 18x11/18x12 track combo. I run 18x11/19x12 F14 in a c6 because I’m a odd ball but will be doing 18x12 soon. I would do a 18x10 and do the R888R 295/18 (10-11 rim width recommended) tire. With a 10” - a 275 or 295 are great options but fit better with same look.
The Forgestar F14 seem to be the common choice for many Corvette owners to do the 18x11/18/12 track combo. I run 18x11/19x12 F14 in a c6 because I’m a black sheep. I would do a 18x10 and do the R888R 295/18 (10-11 rim width recommended) tire. With a 10” - a 275 or 295 are great options but fit better with same look.
Wheel Size: 18x10 Front & 19x11 Rear
Tire Brand:Toyo Proxes R888R
Tire Size: 295/35/18 Front & 305/30/19 Rear
Look right?
Appreciate the help kind sir.
