Different voltage at alternator and battery
Hi, I got a 2004 coupe. Doing all the ground cleaning and checking the wiring. I noticed when I check the Bat + at the alternator the voltage reads 14.4 volts. When I put the volt meter on the battery I get 14.1 volts. Is that normal? Or do I have a bad connection in the wiring from alternator to the battery? Possible ignition switch bad? No codes.
Tia
Chris
Tia
Chris
Moderator, Tech Contributor
Received 2,124 Likes
Was this voltage drop testing done with the engine running ??...that would be a more accurate test....and remember...."no current flow...no voltage drop" !!
