Oil question
Received 1,738 Likes
St. Jude Donor '15-'16,'18
Oil question
I know there are some very knowledgeable folks on this forum with respect to oil. I understand that GM "recommends" Mobil 1 for our Corvettes but I also feel that this recommendation is based as much on a contractual arrangement between GM(Chevrolet) and EXXON/Mobil as it is on the unique properties of Mobil 1. While I have been using Mobil 1 exclusively in my C7 I am curious to know what other oils folks are using in their cars and why? I believe it is correct that any dexos certified oil in either 5W30 or 0W40 satisfies GM specifications and thus will maintain the drive train warranty. Is this correct? I appreciate your input.
Any Dexos 2 certified oil of the proper viscosity will meet the requirement. Go to https://www.gmdexos.com/owner/brands/dexos2/index.html and there is a list of the approved Dexos 2 oils. I use Mobil 1 in all my vehicles (19 GS, Ford Coyote engine in my 1968 Ford XL vert, 2012 Toyota Venza, 19 Hyundai Veloster Ultimate), but that specific brand is not a requirement, just Dexos 2 certified.
rmorin1249 (12-12-2018)
I am currently using Mobil 1 ESP Formula 5w30, which is dexos2 certified just like the 0w40 version is, however when my current supply runs out I am most likely switching over to Pennzoil Euro L 5w30, which is also dexos2 certified (and considerably cheaper, I was paying $17 per liter for ESP, but the Pennzoil Euro is often on sale for $31 for the 5L jug)
I prefer the dexos2 oils over the dexos1 oils because they've got a higher HTHS (they have to be at least 3.5, compared to around 3.1 for most dexos1 oils) Also, the dexos2 oils usually have lower sulphated ash as well, making them better at keeping the engine clean in the long run (very important given the direct injection on these cars)
The following 2 users liked this post by Patman:
Maxpowers (12-13-2018),
Its true any Dexos 2 oil will work...but Mobil 1 Extended Performance is around $25 - $28 per 5 qt jug at Walmart (and less when there's a rebate) - why would you consider another brand that may be a few dollars up or down? Is it worth it to go against what has been recommended since the C4 generation?
4thC4at60 (12-29-2018)
Oh I wasn't questioning Dexos 1 vs 2 - I use Dexos 2 (Mobil 1 Extended Performance) - I was questioning using any other brand vs Mobil 1... The OP mentioned a supposed "arrangement" between GM and Exxon and I challenged why go against what has been recommended (meaning the Mobil 1 brand) since the C4s... I think we are saying the same thing, I was just focusing on "brand" vs certification...
Patman (12-12-2018)
Mobil 1 is a major sponsor of Corvette Racing and I am not questioning that it is or is not a great oil. I was just curious to find out if other C7 owners were using any other brand and why. Thanks for the replies.
Valvoline makes a 5W-40 Dexos 2 MST SynPower full synthetic oil. I might switch to that at my next oil change. I live in FL so having a 0W is not necessary.
Received 1,401 Likes
I switched to Royal Purple on the 88 when I changed the engine, but have since gone back to M1 in all my cars except for my Tacoma, which gets GTX.
As long as you stick with dexos 2 for the warranty you can pick from those. If youre really interested in trying other oils, send samples off for testing. I have done it, it can tell you just how long you should keep the oil in the car and identify some wear issues you might not realize.
Napa, Pennzoil, Valvoline - whatever's the cheapest. Your engine won't know the difference. The Mobil 1 tax is excessive anyway. It's all the same in essence, meeting the API standards.
Personally, I don't see any reason to use anything other than the GM recommended Mobil1 Dexos and PF64 filter. I mean if you can afford a $70,000 sportscar do you really need to save a few bucks on the oil & filter especially considering how infrequently synthetic oil needs to be changed.
I switched to Amsoil Signature Series 5W30 full synthetic on this last oil change. It's not cheap, but run it in my Harley & Honda bikes and it performs well. Having spent most of my life in the oil and chemical business, there's not a lot of difference in the syn oils, with viscosity of the oils being the important factor. Any of the Dexos 2 oils will / would be fine for the C7's.
If you're interested in or running AMSoil, you're good. There's not a better lubricant on the market today. 👍
Received 2,093 Likes
Woodson claims to change his oil every "30,000 miles?" That's kind of foolish to admit.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Yes, it is correct to the OP.
