71 vette signal/side marker wire
Folks, I have wire diagram for MY 71 also checked another 69 book. story, signal on left did not work, right does, but side marker also flashes, so I 'thought'someonhas messed up wire because
both books show brown wire is parking light and lt blue (r/h) and drk blue(l/h) and they are NOT (parking/signal) connected, so I started to unroll black tape and about 1 foot in found that the blue wire has a (factory looking) joint, the blue became the ground for the side marker and not the black. the black tape looked factory, very old. so my question is ín canada did vettes have to have side marker blink with front signal,
ohh another another stupid thing, changed the signal flasher and now both sides flash, should have done that in the 1st place. so question really is does anyone have their side marker flash
along with the front??? so now I have removed the 'joint on blue wire replaced it with a ground like the book shows.and now only the signal flashes like wire diagram shows, but I have to go for a safety inspection after and wonder if I will get nailed for NOT having the side marker flash. (remeber this is in Canada) Thanks Mike.
Received 1,244 Likes
About my '74
With the parking or headlights ON both the front bulb and the side marker blink together.
My front and side lights (1978) alternate regardless of whether the headlights are on or off. How do I go about getting them to illuminate at the same time with the headlights on?
DUB
