C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Best balancer for AA Supercharger on 2012
Old 12-14-2018, 10:22 AM
Florida_1959
Florida_1959's Avatar
Default Best balancer for AA Supercharger on 2012
All,
I am getting ready to install on my 2012 Grand Sport with dry sump the A&A supercharger with the 3.8 pulley. My question is that I need some advice on the best balancer to install. Ill be changing the camshaft so while the balancer is off I wanted to upgrade. I will be having meth on the car so I could possibly go for a little extra boost but not totally necessary. Can anyone advise of the best HB part number / manufacturer to install? I appreciate all the information that people have about this subject. The engine lower is still 100% stock.
Thank you
Old 12-14-2018, 01:21 PM
lt1z
lt1z's Avatar
ATI or IW
You can get both in 6 or 8 rib as well as stock diameter and OD
Old 12-15-2018, 06:44 AM
CI GS
CI GS's Avatar
Received 1,110 Likes on 780 Posts
IW with the oversized “blower” hub. May as well go ahead and get the 8-rib and 10% OD while you’re at it.
And get the IW crank pin kit, they have the neatest crank-balancer pin system out there. BTW: IW balancers come with their own bolt and washer, and if you order the blower hub option, that includes the oversized seal.
Old 12-15-2018, 07:10 AM
old motorhead
old motorhead's Avatar
Received 1,336 Likes on 945 Posts
I have a brand new Powerbond 10% overdrive 8 rib balancer for sale. You can run it 6 or 8 rib. $200 and it's yours. Fits dry sump Grand Sport or Z06.
Old 12-15-2018, 10:52 AM
CI GS
CI GS's Avatar
That’s by far the best deal I’ve seen on a balancer anywhere!
The OP asked about the “best balancer”, but Powerbond certainly is by all accounts the best in terms of price for the quality you get. Hell, at $200, I would buy it myself if I had a dry sump car.
old motorhead (12-15-2018)
Old 12-15-2018, 03:47 PM
Florida_1959
Old Motorhead
Sent you a PM
Im interested in the balancer.
thank you
Old 08-03-2023, 09:36 PM
Mikey965
Mikey965's Avatar
someone posted the 8 rib balancer had the wrong spacing. I want to upgrade to 8 rib, without spending a grand or more. I was going to use the powerbond 8 rib, with Dirty dingo accessory pulleys.
Old 09-12-2023, 12:48 PM
Jason Zajac
Jason Zajac's Avatar
ATI or Innovators West on the high end and Powerbond for a budget minded build
Old 09-17-2023, 10:03 AM
Spaceme1117
Spaceme1117's Avatar
Received 1,312 Likes on 884 Posts
I have a PowerBond Race HB.
Old 09-17-2023, 10:26 AM
C6_Prodigy
C6_Prodigy's Avatar
Best: A&A's secondary belt drive setup and never worry about belt slip or putting extra strain on your accessory pulleys from the tight belt that drives the supercharger. Comes with a custom IW 8" (10% OD) balancer.
Josh@AandASuperchargers (09-22-2023)
To Best balancer for AA Supercharger on 2012
Quick Reply: Best balancer for AA Supercharger on 2012
