Brake bleeding questiion
Hi,
Looking to gravity bleed the brakes on my 78 Pace Car with power brakes and wanted to know if I have to have the car running or have to disconnect the vacuum hose from the booster with it not running?
Pat
Pat
I bought this kit several years ago, used it many times. Works great on hydraulic clutch systems too. Makes it much easier so you don't have to keep getting up to check and refill the master cylinder. Worth it.
https://www.autozone.com/test-scan-a...er/526506_0_0#
