C6 Corvette 2005 underhood light
Old 12-14-2018, 06:56 PM
vettelover8306
vettelover8306's Avatar
Default C6 Corvette 2005 underhood light
Hi Vette owners I'm sure many of you have experienced the underhood light no working... I installed a brand new bulb ... Check connectors ... Don't know the right number for the fuse if some of you know what else I can try I would appreciate any help thanks in advance oh I almost forget it's a 2005 Corvette
Old 12-14-2018, 08:13 PM
4SUMERZ
Race Car Tech
Support Corvetteforum!
4SUMERZ's Avatar
Received 2,320 Likes on 1,664 Posts
The circuit is the Courtesy lamp circuit 10A CTSY LAMP fuse located in the passenger footwell. That fuse shoots power to all of the coutesy lighting including:
Right and Left vanity mirror
Rear compartment lamps
Right and Left courtesy lamps under dash
etc.
If you have any of these other lamps working, then the fuse is not the issue.
You can check the ground for the underhood lamps as per the attached pic.
If all checks out OK, then I suspect that it may be the mercury switch failed in the underhood lamp assembly. In that case, a new assembly would be required. (approx $30.00 from GM. You can check the parts for sale section also. Many cars parts for those that are parting out C6's.
They stopped adding the underhood lamp to the C6 in 2007.Under Hood Lamp - GM Part # (25664746)
Old 12-14-2018, 09:48 PM
vettelover8306
etc.
Hey man thanks a lot for the info this is what I love from this forum as soon as you ask as soon as you get a response yeah all the lamps are working fine ...the only one that isn't working is the underhood one..thanks a lot once again gonna check that ground
Old 12-15-2018, 12:58 AM
owc6
owc6's Avatar
Received 4,186 Likes on 2,679 Posts
My underhood lamp hasn't worked for at least a decade.
Old 12-15-2018, 05:07 AM
vettelover8306
Lmao really ??
Old 12-15-2018, 09:07 AM
BLUDICE
BLUDICE's Avatar
I beg to differ - my '08 has a under hood light offered as an option.
Old 12-15-2018, 09:34 AM
RoadkingC6
RoadkingC6's Avatar
Did you check the connector that runs down by the radiator support, or did you check to see if you have voltage with a test light at the light socket.?
Old 12-15-2018, 10:34 AM
4SUMERZ
Race Car Tech
4SUMERZ's Avatar
Here is more info if you need it
https://www.corvetteforum.com/forums...hood-lamp.html
Old 12-15-2018, 10:41 AM
4SUMERZ
Race Car Tech
4SUMERZ's Avatar
I agree. They were an option after 08/08/06 but they did not come from the factory as standard as in the 05 and 06 and some 07. The other standard deletion was the pull down handle for the coupe rear hatch prior to the 08 models
To C6 Corvette 2005 underhood light
Quick Reply: C6 Corvette 2005 underhood light
