Astro Ventilation Hinge Pin
Old 12-16-2018, 03:40 PM
fastimes
Support Corvetteforum!
fastimes's Avatar
St. Jude Donor '19-'20-'21-'22
Default Astro Ventilation Hinge Pin
I was pleasantly surpised to find my Astro Ventilation intact and operational. Even the drain hoses are in decent shape.
(also discovered some old chalk or grease pencil numbers on the bottom of the plenum.)
However, I noticed one for the rear deck "doors" hanging a bit low. The small hinge pin is missing on that side. I tried seaching a few of our preferred vendors and did not have luck finding one.
I know it's a long shot asking if anyone has a photo of one of these or knows where I can source one?
At some some point I will probably freshen up the seals, etc., but for now, I'd just like to get it back in place so it closes correctly.
I need proper airflow through the car. My Grandma enjoys a good cigar while we drive.
Old 12-16-2018, 06:15 PM
Pmccooey
Pmccooey's Avatar
Here are some photos of mine if they help
fastimes (12-16-2018)
Old 12-16-2018, 06:22 PM
fastimes
fastimes's Avatar
Thanks Pmccooey. I'm actually missing the tiny little pin that the "door" hinges on (if that makes sense).
Old 12-16-2018, 06:27 PM
DUB
DUB's Avatar
Received 2,713 Likes on 2,321 Posts
Are you referring to the pin that the yellow arrow is pointing to???
DUB
fastimes (12-17-2018)
Old 12-16-2018, 06:35 PM
DUB
DUB's Avatar
I have this area out of a car and I can take a look at the door and pivot pin and see if I can see something that can help you out tomorrow.
DUB
Old 12-16-2018, 07:49 PM
Pmccooey
Pmccooey's Avatar
I’m trying to think of the piece your talking about. It basically a piano hinge with a long bar going through it with little circle push on nuts (like the ones on some trim pieces) that holds it in.
Pmccooey
Pmccooey's Avatar
Or the other side like Dub is showing?
Old 12-16-2018, 11:56 PM
fastimes
fastimes's Avatar
Here's a couple of bad pics
Old 12-17-2018, 12:32 AM
fastimes
fastimes's Avatar
It's the pin DUB is pointing out
Old 12-17-2018, 12:40 AM
fastimes
fastimes's Avatar
Some markings I found on the bottom of the plenum
" 214 R"
Don't know what it means, but it's cool to see
Old 12-17-2018, 10:00 AM
Pmccooey
Pmccooey's Avatar
You could go to any hardware store and get some round stock in the right size and fab that up. Or do you have the round bar but nothing at the ends to keep it in place?
Old 12-17-2018, 11:47 AM
birds69
birds69's Avatar
The pin your talking about measures 1" long, 1/8" rd. I used a couple old 1/8" drill bits. cut to size. Worked great.
Old 12-17-2018, 11:54 AM
Easy Mike
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
...Some markings I found on the bottom of the plenum..." 214 R"...Don't know what it means...
214 is probably the job number. Do you have a factory radio (the R)?
Old 12-17-2018, 01:01 PM
fastimes
fastimes's Avatar
Yes, U69 Mono Radio option
Old 12-18-2018, 12:07 PM
fastimes
fastimes's Avatar
214 must be the job number. I found it typed backwards at the top of my build sheet. Pretty cool.
To Astro Ventilation Hinge Pin
Quick Reply: Astro Ventilation Hinge Pin
