[Z06] 04 Z06 Shock Upgrade for 01...
So it looks like the OEM front shocks for the 04 Z06 are discontinued...
However, according to this link, http://www.kandbcorvetteproducts.com...and-driveline/, SACH 030 281 is equivalent. Can anyone confirm that this is the case? If not where can I source a set of OEM front shocks? I already have the rears so I don't want to switch to another brand for the sake of consistency.
Received 2,705 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
I believe the C6 Z06 shocks are a direct fit as they were for my C5 coupe. They are still available from forum vendor Gene Culley.
Pro Mechanic
Any of the C6 shocks can be used on a C5, besides the magnetic ride ones. C6 base- softest ride. C6 Z51- firmer ride. C6 Z06- firmest OEM ride. Firmer generally equals better handling.
Not sure if the 01 Z06 had the plastic endlinks or not on the sway bars, but if you do have plastic endlinks, now is a good time to upgrade to the metal ones. The plastic ones are most likely worn out by now.
Received 19,199 Likes
'20-'21-'22-'23-'24
I agree with the above - the C6 Z06 shocks are a good choice.
