C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] CEL Flashes for a couple of seconds on start up
Old 12-17-2018, 11:39 AM
Z0HM6
Z0HM6's Avatar
Default CEL Flashes for a couple of seconds on start up
Hows it going everyone. I've been looking around and don't think anyone has had this problem. When I'm warming the vette up in the morning, the check engine light flashes between 5-30 seconds, then goes away.
No driveability issues whatsoever and no codes found. My car runs smooth, idles fine, and screams bloody murder when I punch it with no hiccups. Only happens on a cold start after the car has sat for several hours. If I let it warm up and then turn it off and on no blinking cel. Only started after my tsp stage 4 cam install. New MSD 8.5 wires and new spark plugs.
Thanks for taking a look at my issues and I look forward to any responses you may have..
PS, are traction modes disabled if your tire psi reads zero? Threw on a drag pack and I can only turn traction on and off but cant switch to competitive etc.
Old 12-17-2018, 11:48 AM
jayyyw
jayyyw's Avatar
Obvious question; did you get a retune after installing the cam?
Old 12-17-2018, 11:52 AM
Landru
Landru's Avatar
Received 1,047 Likes on 821 Posts
Any code(s) set?
Old 12-17-2018, 12:59 PM
Z0HM6
Z0HM6's Avatar
Yes the car was tuned.
Z0HM6
Z0HM6's Avatar
Originally Posted by Landru
Any code(s) set?
Only code that shows up is p0300
Old 12-17-2018, 01:45 PM
DaOtherOne
DaOtherOne's Avatar
The check engine light will do that when misfires occur.
Make sure all of your spark plug wires are tight.
Old 12-17-2018, 03:06 PM
Z0HM6
Z0HM6's Avatar
I just got boots for the spark plug wires. Redid all the wires and I’m sure they’re all on tight
Old 12-19-2018, 10:52 AM
Landru
Landru's Avatar
You'd better re-check those plug wires, again.
Been here a long time, can't recount all the instances where owners swore plugs were attached properly.
Chased many-a-rabbit down holes only to learn they were wrong.
0P300 is the clue, here.
Something's not securely connected.
G/L, re-check your work & make sure plug boots are 'burped'...look-up the term.
Old 12-19-2018, 11:01 AM
Z0HM6
Z0HM6's Avatar
Gonna pull all the plugs and check them again. Just to make sure, the plug that goes into the spark plug clicks once and twice for the boot the plugs into the coil? Spark plugs are brand new and have been gapped to .040. Anything else I should check for. Really annoyed that it happens every single cold start
Old 12-19-2018, 11:09 AM
Z0HM6
Z0HM6's Avatar
Any chance heat from the headers can ruin the msd wires? I have no boots on them.
Old 12-19-2018, 12:29 PM
Apocolipse
Apocolipse's Avatar
Received 1,282 Likes on 927 Posts
The tuner probably did not adjust the idle misfire table
Old 12-19-2018, 12:36 PM
redbird555
redbird555's Avatar
The car isn't actually misfiring isn't. large cams will trick the pcm into thinking the car is misfiring. It likely does it when cold because the car idles a little harsher then. T33he misfire tables just need to be dumbed down not a big deal
Old 12-19-2018, 12:38 PM
Apocolipse
Apocolipse's Avatar
Multiply the idle table and running table under 4k by 1.2.
Old 12-19-2018, 12:49 PM
Z0HM6
Z0HM6's Avatar
My tuner maxed out all the misfire idle tables. I asked him to show me to verify. I believe he multiplied everything by 5
Old 12-19-2018, 12:51 PM
Z0HM6
Z0HM6's Avatar
That's what I thought and that's what my tuner is saying. It is a tsp stage 4 cam and it only likes to do it on cold start ups after its sat several hours. I won't do it once its warm and I've tested this to make sure. Daily'd her for a day and no cel blinking after the initial start up as long as the engine stays warm. Misfire tables have been maxed out.
Old 01-17-2019, 02:43 PM
Z0HM6
Z0HM6's Avatar
Still hasn't been resolved.
Old 01-18-2019, 06:09 PM
joshp14
joshp14's Avatar
Monitor misfire counts on a cold start and see if it's isolated to one cylinder or several. This will give you a better direction for diagnosis.
To CEL Flashes for a couple of seconds on start up
Quick Reply: [Z06] CEL Flashes for a couple of seconds on start up
