Mobil 1 15W50 cuts wear in half
As the title states see attached, universal averages are for 5W30 M1.
On a side note, I am using the same oil my LS based marine engine with similar results vs MFG recommended fluid.
Are you saying it makes wear parts last twice as long (meaning the amount it wears is half as harsh as with 5w30) or that they wear out twice as fast (meaning the wear time is half as long)? I can't make heads or tails of that pdf.
C7X46....your statement confuses me. Your title says 15W50 Mobil One cuts wear in half and your sentence in the body of the post says universal averages of 5W30 Mobil One, which is what the 15W40 is being compared with.. The wear metals of the 15W50 are only slightly lower than the 5W30 and in some cases identical...the 5W30 wear rates could very well be within the specifications of the Corvette engineers. The additive packages are much higher in the 15W50, which is nice, but that doesn't prove the 15W50 engine is wearing at half the rate of a 5W30 engine. What am I missing here?
I think they may be claiming it because of the higher ZDDP numbers in the 15W-50, which is advertised as having a higher anti-wear package recommended for flat tappet cam engines. I've only used Mobil1 15W-50 since rebuilding my '66 L79 back in '90 when the ZDDP levels were just starting to be looked at by the Government.. ZDDP levels were reduced due to a Government regulation because supposedly high ZDDP levels hurt catalytic converters so it became a smog/pollution issue.
https://mobiloil.com/~/media/amer/us...pecs-guide.pdf
If my interpretation is correct, then I believe the conclusion you drew may be incorrect. The wear metals PPM's are very close, sometimes the same between the two columns and I have no idea what GM/Chevrolet allows for wear materials in an XX hour running cycle. Technically, the hours on the oil is a convenient but very inaccurate way of measuring "oil life". The real way to do it is "gallons of fuel thru the engine". I don't know if Chevrolet has ever released that number for it's customers, but you can bet the ranch the engineers know that number. The additive packages in the left column (the 15W50 oil, I think) show healthier numbers and my guess would be that the 15W50 oil is used primarily for racing applications and the load factors on that engine in racing vs. street driving are off the charts, different/higher.
You could be correct with your statement that wear levels are much lower with 15W50, but I can't see that conclusion in the chart you provided.
It is all I run in my 496 HO that powers my SeaRay 270 sundecker. The thing I notice the most is that coming out of the hole before I used the 15w-50 I would get a nasty piston slap....since changing over there is no slap at all.
I'm not sure of the parallel comparison of a Mercruiser 400+HP I/O in a pleasure craft vs. and a 6.2L Supercharged 650 HP Corvette engine. What I can assure you is, the boat industry is easy peasy on high horsepower engines and load factors....it is the very easiest application in the engine world, short of a stand by generator in a hospital. The load on the boat engine is created by the prop turning in water, whether the boat is moving or not. We used to test boat engine HP by putting the bow against a dock and after the gauges were installed, fire up the engine pushing the boat against the dock. Works great every time....glad you're using 15W50 in the Mercruiser, nice to know.
I am using it in an Ilmor MV8 7.4, we are pulling almost 10,000 LBS with it heavily loaded for surfing and it operates all day just under peak torque. The factory fill was M1 5W-50 when I bought the boat, later in the product life cycle M1 15W50 was added to the approved list for the engine by Illmor. The 5W50 seemed to shear down around 30-35 hours and pressure dropped 10PSI hot, in back to back testing 15W50 cut wear metals in half. I would be curious to know what the lowest wear metals others have seen using the factory fill on a similar change interval.
I’ve been running M1 5-50 for a year now In in my 16 Z m7. It has the maggy 2300, kooks LT,AFE,lower pulley, X tank and tuned. Excellent oil for both street or track. As we all know GM will run the thinnest oil possible for fuel economy and also it needs to be all season meaning all temperatures country wide. I never cared much for the 5-30.
Received 1,816 Likes
A car requires only about 15 horsepower to go down the freeway, and typically only sees about 10 seconds of sustained full throttle at a time
A boat may need 30-100% full power just to maintain cruise speed (depending on the boat, the engine, and what the owner considers to be "cruise speed"), and owners flat-foot their engines clear across the lake quite regularly.
Received 2,379 Likes
I run only 15-50 in all my cars, including the ones with cats.
OP, actually your "wear metals" with your 15-50 oil are about the same (or very close) to Brookstone's "universal averages" for LT-4 engines using 5-30, with the exception of lead. If my understanding is correct that LT-4 engines don't use lead-plated bearings, I wouldn't know how to explain that part.
However, you did put about twice the mileage on the oil, compared to the mileage Brookstone Labs claims they use for their "universal average", so you might be on to something.
For what its worth I too thought oil is oil & oil additives really don't help until I switched from Mobil 1 oil to this super trick super slick oil that I found out about that had a moly additive in it. Ran this oil in my race engine all season then took it to my engine builder to get freshened up. After tearing down the engine he called me & asked me if I even ran it.
*This was in my nascar oval track car with Flat tappet cam motor, going from Mobil 1 5-30 to 3-30 oil with a moly additive.
*The only oil that I know that has high levels of zinc in it is Joe Gibbs racing oil but it doesn't have the super slick moly additive in it.
This is my marine application, and I absolutely love this engine, makes its rated power on 87 octane and shakes with cam lope.
20K for the upgrade and I wouldn't consider a boat of this type without it.
https://www.ilmor.com/Marine/Other-Inboard/MV8-74L
http://www.mastercraft.com/video/detail/46/trailer
Wrong!!!!!
You are incorrect about this. The fact that the prop "slips" somewhat in the water is irrelevant. The prop is sized and pitched to absorb the engines full horsepower and torque. The engine can't be worked any harder than this in a wheeled vehicle, or any other application.
Interesting conversation. If you watch this video it's Mercury Marine talking about peak power vs durability in Marine and Auto applications. They mention the power numbers are "conservative" because as a marine engine builder the wide open throttle stresses on open water are much harder on an engine.
https://youtu.be/pNCIWLtdVKs
