Mirror problems help
I have my mirrors ans seats set on memory. But each time I get into the car both the mirror moves downward and I need to readjust. It just started doing this. Its a pain in the *** .Any suggestions why' All other adj. to memory and both fobs work fine.
Page 43 & 44 from the 2018 Owner's Manual (see Reverse Tilt Mirror section):
Seat Memory Settings
Some owners have had trouble getting their driver settings to save. Thanks to another owner, we’ve learned that this is the best process:
• Start your Corvette and select “Settings” on the Infotainment screen.
• Scroll down to select “Vehicle;” then select “Comfort & Convenience.”
• Select “Auto Memory Recall” and turn it Off.
• Back up one menu to select “Easy Exit Options” and turn this Off as well.
• Adjust your seat, steering wheel and mirrors to your preferred driving settings.
• At the same time, press the “Set” button and the “1” or “2” button. A beep will
sound to confirm your settings.
• Move the steering wheel up and the seat back as far as it will go; then move the
seat forward about a half-inch. At the same time, press the “Set” button and the
“Exit” button. That same beep will indicate that your setting was saved.
• Go back to the Infotainment screen and turn “Auto Memory Recall” and Easy Exit
Options” back on. The next time you get into your Corvette, the settings should work.
Hopefully, the procedure MMD posted above will work for you. Let us know how it turns out.
https://www.corvetteforum.com/forums...all-issue.html
I also live i Fleming Island. Eagle harbor). I started this thread in Dec 18 and I can< find the problem either. Maybe it is a Fleming Island virus.Let me know if problem resolved teddykraut@yahoo.com
