69 side mirror, glass removal
Old 12-18-2018, 02:53 PM
Dave Cunningham
Dave Cunningham's Avatar
Default 69 side mirror, glass removal
i goggled this but didn't come up with much, probably because it is impossible. The original side mirror on my 69 needs replating to be perfect, and I need to remove the date coded glass, and disassemble the mirror, is this possible?
Old 12-18-2018, 03:08 PM
Hammerhead Fred
Hammerhead Fred's Avatar
Try these instructions (pics included_
http://www.corvettefaq.com/c3/chrome_mirror.pdf
74_stingray (12-19-2018)
Old 12-18-2018, 04:11 PM
C3 Stroker
C3 Stroker's Avatar
Let the mirror soak overnight in lacquer thinner. The glass will loosen and come right off.
Old 12-18-2018, 04:37 PM
69ttop502
69ttop502's Avatar
This works great!
Old 12-18-2018, 05:28 PM
theandies
theandies's Avatar
I used gas in a bucket. Just leave it outside for safety. It only took a hour or so.
Old 12-18-2018, 06:48 PM
Dave Cunningham
Wow judging by the responses it works , I'll try it tonight and let you know how I make out, thanks guys!
Old 12-18-2018, 08:04 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
It works. Just sit it face down into the gas or lacquer thinner (uses less fluid). It'll be loose shortly....
Old 12-18-2018, 10:34 PM
theandies
theandies's Avatar
This might help if your mirror is not tight and starts to droop at speed:
How to fix your droopy side view mirror
Old 12-19-2018, 09:09 PM
Dave Cunningham
Update, soaked it in lacquer thinner all day, no luck yet, chipped the corner ever so slightly tying to pry it a bit.
Old 12-20-2018, 04:03 PM
7T1vette
7T1vette's Avatar
Is it possible that your mirror has already had a "repair" made to it? The usual 'fix' is to reattach the mirror using Ultra Black RTV....and that will NOT cause the mirror to detach. The same may be true with some aftermarket mirrors. (but I think you stated that it had an original date code?)
Old 12-20-2018, 09:02 PM
croaker
croaker's Avatar
I used gas also overnight.
Old 12-20-2018, 09:09 PM
69ttop502
69ttop502's Avatar
Dave, I have a spare piece of 69 mirror glass if you or anyone else needs it. Free of charge!
Old 12-20-2018, 09:33 PM
stock76
stock76's Avatar
I soaked mine for two days with the gas method and the original mirror glass came right off.
Like with all old things, you gotta be patient.
Old 12-21-2018, 07:26 AM
toylman
toylman's Avatar
7T1vette is probably right, if it is factory adhesive, it will fall off pretty fast in the gasoline soak. I have 2 small diamond files, a 320 and 600. Using wet, I can file out edge chips in glass.
Old 12-22-2018, 12:38 PM
Dave Cunningham
Well it's been three days, and the mirror is still stuck, mind you , I was using Laquer thinner, not gas, I suspect that someone replaced it already with date coded glass, just like I will after I pry it out of there and break it in the process. Great tip though , I'm sure it works perfectly on an original mirror.
Old 12-22-2018, 09:02 PM
theandies
theandies's Avatar
Try gas before you destroy your mirror. Should work.
Old 12-22-2018, 11:50 PM
7T1vette
7T1vette's Avatar
Worth a try...
To 69 side mirror, glass removal
Quick Reply: 69 side mirror, glass removal
