[Z06] 2009 displaying many faults, dealer stumped
Hello,
My 2009 Z06 ( 39,000 miles) decided to display many faults the other day: Service ABS, Service Traction Control, Low Fuel ( just filled up 2 days prior ), Brake ( ebrake not on ), Check Engine, Fuel gauge went to empty, and then it wouldn't start. Called for tow, and 10 minutes later it started. I have read threads about cleaning the grounds and connectors in a C5. Dealer has car and can't figure out the problem. No codes were thrown. Their diagnostic computer having problems communicating with my car. That goodness for an extended warranty. Any ideas/suggestions? Thanks
Bad cell in the battery maybe. Bad batteries always cause these sorts of gremlins. I would hope to God they've at least done a load test on your Battery.
battery going bad on my dear departed c6z made for wonky behavior. If the car sat for any lengthy time with out a battery tender I would replace the battery first. Especially if battery is near 3 years old or more.
Received 4,689 Likes
Like the others have posted, start with the battery
There' another possible source for this, assuming battery confirmed healthy.
How frequently do you have a rider?
The fuse box is under passenger footwell, under panel's fuses etc + 2-3 large blue connectors.
Passenger(s) exerting excess downward force, such as when going through a sharp turn or just heavy, instinctively press downward their weight.
Weight xfers through the flimsy panel pressing on these critical connectors resulting in some really weird behaviors, like yours.
Owners either had to pay the devil or get really lucky identifying this while troubleshooting like issues.
It's rare but has been reported at least 2-3 times over C6 run.
Once confirmed installing some kind of shim between panel's rear & blue connectors supporting/deflecting weight seemed to do the trick.
One member used a couple Pink Pearl erasers as shims, worked fine.
Not hard to check, open panel, bright blue connectors are right there in plain view.
Worth the time checking those connectors making certain they're firmly seated -- if only to rule 'em out.
FWIW members also put a tab of dielectric grease on plug pins before reconnecting plugs.
JDebler (12-19-2018)
Z06 2009 displaying many faults, dealer stumped
Thanks to everyone for suggestions to fix problem. Battery good. Everything grounded good. Dealer still stumped after 3 days. Probably not working on it 8 hours a day. I love it when I pass on your suggestions to a supposedly corvette expert. I will post the final results when they are known. Any more ideas are appreciated.
Bow-Tie Guy
Totally Agree This Should Be Checked
Landru (12-20-2018)
As everyone else has said or referred to, the battery is the culprit most of the time. Ask, beg, plead for them to try another new battery. The errors have nothing to do with each other which leads us and past posts to the battery... Even if it load tested ok
I know that it’s not the same car, but my son’s 2010 camaro w/6l80 did the same thing after sitting for 2 months while engine was rebuilt. Finally found the big round connector in the back of the trans was slightly pulled out when moving engine harness out of the way to pull engine from top. Nothing on the car would communicate and fuel gauge was reading empty like you stated. Must have a termination resistor in trans control unit that allows all modules to communicate. Maybe your car has a similar connector somewhere that disrupts the can. Obviously not an auto or camaro.
Final Update on multiple faults in my 09 Z06
Got my 09 Z06 ( 40,000 miles) back today. Short story - can't find cause of multiple errors. The tech, 30 years of Corvette experience, sat down with me and showed me every circuit he could test/touch. For the first few days, the errors would go away and come back several hours later. A couple of the "CM" s would not talk with each other. High speed Lan dropping out intermittently. Finally the errors did not come back after 5 days. He guessed that his touching made connections work again but can't name which one. All is well. I did have them install a new battery per your suggestions. But that was after all the errors went away. Very happy with Henry Brown Chevrolet here in Casa Grande AZ, especially when they charged me for only the battery after 8 working days. Thanks to all who provided input.
Had the same thing happened to my wife's 2008 ctsv. Chased down the issue for years as the car is seasonal here in the winter time. Seamed always to be temperature related and we ended up keeping scan tool hooked up when we traveled together somewhere of distance. The high speed serial data line would drop out intermediately and I finally chased it down to the EBCM. I know it seems strange that it would effect this much stuff but trust me it will!
Another Update, Spastic gauges back on 2009 Z06
Well sports fans, previous gauge problem that went away after 9 days at the Dealership ,is back after 25 days. They wiggled and jiggled connections and problem went away. Out for a drive down here in Casa Grande Az on Jan 12, 2019, the gauges went spastic again on I-10. Wouldn't start after eating breakfast. Brand new battery. Open driver's door and closed a couple of times and she started. What a fix !! Back to dealer today. And of course the gauges are all functioning perfectly. So dealer has to monitor over night and try to recreate the problem. BCM functioning "normal". It was replaced back at 8000 miles via a service bulletin . Now have 40k. Bad BCM? time will tell. Loose wire in driver's door? Who knows. Maybe, Maybe not. Can't trust car now. Especially since it won't start after being turned off. I would be happy with opening and closing door if that solved my short term problem. Will there ever be an actual FINAL update? Stay tuned! Sorry for the pun.
Landru (01-15-2019)
