Southern California Southern California
Smog Check and Rear Oxygen Sensors
Old 01-02-2019, 02:57 PM
crznZ06
crznZ06's Avatar
Default Smog Check and Rear Oxygen Sensors
Assuming a car passes the visual inspection, if a car's rear oxygen sensors are deactivated, and its PCM is flashed so no codes are stored and the check engine light is not activated, can it pass a smog check? Thanks.
Old 01-03-2019, 10:18 AM
Medrivfast
Medrivfast's Avatar
If it's a 2000 or newer all they do is plug into the obd2 for smog. Make sure the monitor's are ready to pass
Old 01-06-2019, 03:28 PM
dugsgms74
dugsgms74's Avatar
The only monitor allowed to be "not ready" is Evap so if the O2 monitor can't run and pass then you will fail even if the engine light is off and no codes are stored.
Old 01-07-2019, 02:17 PM
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
They do a visual if there is no codes and the O2 sensors are in place you only have to worry about the "sniff-test". In my 1996 LT4 I failed miserably; It was so bad the report said "GROSS POLLUTER". I bought two new California catalytic converters and I passed. The guy said: "It passed super clean"
Check it out, with those CA crap cats, the car is super lazy and I get less MPG.
Old 01-09-2019, 08:39 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
x2 reaplaced them on my SIlverado it feels like a slug. Prior to that pig used to get wheel hop hitting passing gear with the originals on there.
Old 01-18-2019, 01:04 AM
Blue Blood
Blue Blood's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
On my ‘02 I don’t have the rear sensors and they’re tuned out. Been though two checks, most recently last January, no issues either time.
To Smog Check and Rear Oxygen Sensors
Quick Reply: Smog Check and Rear Oxygen Sensors
