Anyone use portable 2 post car lifts?
Looking to buy a portable 2 post car lift, I see a couple options, however I prefer something made in America, anyone find a good one?
I just finished shopping for a two post lift for my home shop. I ended up with the Dannmar M6 portable lift. I wasn't so concerned about portability but finding a lift that would work with low ceiling height was a main factor. The M6 is a hydraulic two post lift that will will go up 45". which is about the capacity of my garage here in SoCal. The posts are anchored to the concrete with 5 threaded anchors. The power unit is on wheels and the two hoses use quick connect dry break couplings. To move the lift, you unscrew the bolts (5 per post) and the posts can be tilted back on their wheels and moved. I do every possible service on my cars and that includes engine and trans work so a scissors lift or drive on lift was not an option for me. A full size lift would not work in my garage unfortunately.
With the exception of having to use a creeper or a roller seat, the lift is as versatile as a full height two post lift. The Dannmar is made in China but is AIL certified and comes with a 3 year warranty. SInce I do not plan to move it, I ended up mounting the power unit on the wall and ran the hydraulic hoses overhead since I have no plans to move the lift until I move.
I bet most post lifts aren't very portable due to anchoring.
I use a quickjack. It has made my life easier many times. It lifts to about 20" which is enough for anything I want to do at home. It is completely portable.
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
I second that. I just cut 4 pieces of 1 1/2 inch rectangle steel to shim up to the URO jacking pucks. I haven't finished the project but I think this will be a great combination to raise the ZR1 with my quick jack.
It was hard for me to justify $1100 for a Quickjack which really only allows wheels and brake type service with a max lift of 20", when a true two post lift with unobstructed undercar access and a 45" lift height was only $900 more from Dannmar. I've used both and for me, the Quickjack is just too limited. The arms on the M6 are only 3.5" and low enough that it doesn't even require the typical drive on boards for my C5 or R8. The main drawback to the M6 is it absolutely needs to be anchored while I don't think the QJ does.. A significant difference but worth it to me.
Art17 (01-22-2019)
Will your 4 post lift fit in the back of a pickup truck or van like my two post lift or a Quickjack? How about vehicle suspension work or removing an engine or trans? How does that work out on your 4 poster? Don't see many 4 post lifts in dealerships because they are inherently designed for storing cars or as alignment racks.
Received 8,927 Likes
My MaxJax lift posts are sitting in the corner of my garage where they are out of the way until I need to use the lift again. The lift anchors are sockets Vs studs so don't cause any issues when the posts are stored in the corner. The garage floor is completely usable. If you decide to leave the lift in place it can also be used to stack cars. My ex-neighbor used to have a Lexus sedan he would park on the lift and then park his Miata under it. The M6 is identical to the MaxJax other than it has more safety bar holes to provide more lift positions than the MaxJax provides with its two positions.
Bill
Bill
Supporting Vendor
Received 2,316 Likes
In the end, I bought neither and just went a whole new route....no obstructions, doesn't need deep anchors, unobtrusive to anything that needs worked on 95% of the time, etc....BUT...a HEAVY pair of slabs to move. There is no "perfect" answer to the lift problem.
I use a quickjack on top of my 4 post lift and I also have an adjustable jacking tray which gives numerous combinations of what you can do. I also use one of the runners as a crane if I have to.
Being able to move it while the car is on is such a huge plus, I don't think I can over emphasize that.
They each have their advantages, but 2 post lifts aren't as portable as you think.
I actually used to prefer the 4 post and definitely did suspension and brake work. A 4post combined with tall lift jack stands is pretty quick and convenient. Easy to get the car in the air really quick and get working. I really debated getting another 4 post, after getting rid of my 4 and my 2 I had. I like the 2 posts for sure, but many big 2 posts require more slab thickness than many places tend to have, in order to truly be safe. 4 posts don't even need anchored at all.
Bill
Supporting Vendor
In honesty, aside from moving it, which frankly all are difficult, its unbeatable in terms of access and ease of getting the car in the air. They are pricey though, compared to the lower level propark 4post and atlas 2 posts. Very solid lift though, very glad I went this way.
The issue with the concrete depth for the 2 posts is always my concern. If you dont have a solid 4 inches and 30" distance from the nearest edge, youre asking for trouble/maybe dying under that lift. This lift aint goin anywhere and I pull in right over top of it like its barely there.
Thanks!
NSFW (01-21-2019)
I understand you guys are into doing all things necessary to your vehicles. The quick jack does all I need for regular maintenance and light work. If I need access to a 2 post, I just let an automotive shop do the work. Besides, some of that heavier work (replacing tranny, clutch or engine) just ain't as much fun as it used to be.
Supporting Vendor
I installed the Danmar M6 right after Christmas and it's the bee's knees. It bolts into the floor with concrete anchors so it is indeed portable. The hydraulic pump rolls around with the posts and just plugs into the wall, so it's super easy. Don't know how I lived without a lift for so long!
To correct what was posted earlier regarding the differences between the M6 and the MaxJax, The M6 is equipped with automatically engaging lift safety locks at 7 positions, while the MaxJax requires the user slide locking pins into 1 of 2 positions on the posts. This is why the MaxJax is not ALI certified. The lifting arms were different as well when I made my purchase and were 3.5" where the MaxJax was 4", however I think they are the same now.
Here is a link to the comparison chart. file:///C:/Users/Steve/Start%20Menu/Saved%20Games/Desktop/Dannmar%20Web%20Chart%2012-13-2018_revised.pdf
Supporting Vendor
Problem I had, is I've rented 4k sq/ft+ commercial spaces that didn't have a 4" thick slab. In some sections of the country I think it's just common...but in the old Northeast...buildings that are built in the 40's or earlier...hard to find. Best thing you can do is cut out the squares, intertwine rebar and pour new foundations for the lift. For that reason I often had 4posts and now I have the scissor. Gotta REALLY watch your concrete is sound with a 2 post or you're lookin to die.
