My first vet c5 what should I do first.
i just picked up my first corvette and it’s. 1999 coupe with automatic that has 26,467 miles on it. It is immaculate and I just don’t know where to start. The oil gauge said 60% life.. and all the fluid levels seem ok. It runs great. I was thinking about changing all the fluids this coming spring but someone said to only change the oil and coolant. Transmission and transaxle fluids should not be changed because they can lead to issues. What should I do?
The following 4 users liked this post by TastyBacon:
1/4 mile/AutoX
Acquan (01-14-2019)
1/4 mile/AutoX
check date code on tires ????
gimp (01-14-2019)
The tire date code will be on the sidewall of the tire. They are usually on one side only but they are easily seen. The format is a 4 digit number; the first two numbers represent the week of a year when the tire was made.and the last two number will be the year of manufacture. An example would be something like 2716 where 27 is the week and 16 is the year. Most people say to not keep tires if they are 5-7 years old or signs or cracking on the sidewalls or the tread.
El original (01-14-2019)
Clean out the radiator by blowing air from back of radiator toward front.
Change out fuel filter.
Change all fluids.
Check wiper blades.
Check belts.
Check radiator hoses.
Check all bushings, ball jounts and tie rod ends.
This is a good start. I do this whenever I buy a "new" car.
Spaggs
Change all fluids.
Check wiper blades.
Check belts.
Spaggs
Do you know how old the battery is? If not, try to find a date code on it. If it's more than 3 years old or if you can't figure it out, have the battery tested at a auto parts store that will do it for free.
Acquan (01-15-2019)
I know the owner's manual says the 6 speed fluid is good for life and the auto transmission fluid should be replaced every 100k miles, or 50k with severe duty.
I changed my 6 speed's fluid anyways, and the shifting was noticeably improved. When you change your automatic's fluid, just drain and refill. Don't flush. That's what can lead to issues. Basically a shop's flushing equipment can contaminate your transmission with someone's else dirty fluid.
I don't know if differential fluid has a recommended change interval, but I went ahead and did it anyways for peace of mind. Unlike when the cars were new, you can now get AC Delco gear oil with the anti-slip additive already mixed in the proper ratio. After you change the fluid, there is a break in procedure to follow. Do figure 8's in a parking lot to work the new fluid into the differential's clutch packs. And no hard acceleration for, I believe, 500 miles.
Radiator hoses are a good suggestion to check. The original owner of my car had them replaced about 8 years into its life. And I replaced them again after I bought it, since I live in a hot climate and didn't want to risk failure. Also my coolant overflow reservoir got a leak and I got a new one, as well as I just replaced the radiator. (It started leaking near the upper flange) Just keep in an eye on your coolant level.
Also if your car is still on its original harmonic balancer, there is a good chance you'll need to replace it once you start driving it frequently. The original balancers commonly fail. My original balancer started wobbling at about 50k miles.
The following 2 users liked this post by grantv:
Acquan (01-15-2019),
digitaloutsider (01-27-2019)
1/4 mile/AutoX
The registered my car as being silver but I was looking at the build sheet and it states 921-MED DK PUTER II (99)
the corvette black book book doesn’t have that color listed for a 1999 so what color is it?
I think I’m confused with the color... the more I look at this GM build sheet the more confused
i see in the left column
921- MED DK PUTER II (99)
right column
13U BRIGHT SILVER MET
right column
Post a pic of it outside in natural light, and we can prob. tell right away what one it is or google the colors and you'll see the difference
Acquan (01-15-2019)
1/4 mile/AutoX
My 99 ,,,Sebring Silver Metallic
Corvette#2 (01-21-2019)
