Questions about aftermarket headlights
Old 01-15-2019, 08:08 AM
grampi50
grampi50's Avatar
Default Questions about aftermarket headlights
I see a lot of threads where people upgrade their headlights, either to LEDs or the Radios. Is this upgrade on the low beams only, and if so, do they then become brighter, or provide better night vision than the OEM high beams? Are there upgrades for the high beams as well?
Old 01-15-2019, 09:00 AM
Fast one
Fast one's Avatar
I used four bi xenons so one set is on low for low beam and all go on in high for high beam, more light in both modes especially in hi beams.
Old 01-15-2019, 10:13 AM
GCG
GCG's Avatar
I would suggest Bi-Xenon ACAs (where the lows play double duty as lows and highs, in addition to whatever bulbs you have on the high reflectors) and upgrading the foglights with
<b>these plug-and-play bulbs</b> these plug-and-play bulbs
The ACA is a complete headlight housing and with a Bi-Xenon projector the results are really incredible.
BlackHellcat (01-15-2019)
Old 01-15-2019, 10:43 AM
BlackHellcat
BlackHellcat's Avatar
C5 of Year Finalist (performance mods) 2019
Looks like the simplest way is putting HIR bulbs in
grampi50
grampi50's Avatar
Originally Posted by GCG
I would suggest Bi-Xenon ACAs (where the lows play double duty as lows and highs, in addition to whatever bulbs you have on the high reflectors) and upgrading the foglights with these plug-and-play bulbs.
Do you know how much the ACAs sell for?
Old 01-15-2019, 02:34 PM
grampi50
grampi50's Avatar
Anyone?
Old 01-15-2019, 02:50 PM
Velocity_Vette
Velocity_Vette's Avatar
~$700 when it's all said and done for ACAs.
I'd like to point out something that I don't think gets talked about enough when talking about headlights. Headlight bulbs do have a 'life' of sorts. Most non-LED headlight bulbs start seeing serious quality deterioration within roughly six years of use. C5s are a product of the 90s and I'm certain with how low mileage some cars are there are many near and 20+ year old cars rolling around that have never had their headlamps changed out. Lighting technology has also leaped quite a bit since 1997. A lot of times a simple replacement can do wonders, and if that isn't satisfactory a good HIR bulb works wonders (why on Earth 9011s and 9012s are just that slightly different to 9005s and 9006s that they require a tab snip is utterly beyond me. Seems like from a manufacturing stand point you'd WANT HIRs to supersede the old 9005s and 9006s).
Old 01-15-2019, 03:40 PM
grampi50
grampi50's Avatar
What are HIRs?...and I don't think I want to spend anywhere near $700 on headlights, I was thinking more like less than $200...I saw Chris' video (the "my corvette life" guy with all of the "how to" you tube videos) on his installation of LED replacement lights, and he said the kit was only like $50...the difference between the LEDs and the stock headlights was incredible!
Old 01-15-2019, 05:33 PM
gimp
Support Corvetteforum!
gimp's Avatar
The "ACA" variants go from around $280 on the low end, to $700 on the high end, depending on the quality you're looking for. Ebay may have even cheaper ACA setups.
Plug-and-play LEDs are doable but they're generally not nearly as good as a good, properly aligned projector setup. Brighter does not necessarily mean better. The way the light is projected really matters. You may end up spending most of that extra light dazzling the eyes of other drivers, and get relatively little improvement in the distance you can see. You also may well end up with lights pointing wrong, with bad cut-offs. Do your research.
HIRs _were_ basically lights that used a coating on the inside of the light to reflect heat back into the filament, making it brighter (halogen infrared), trading brightness for longevity; they were drop-in replacements. Today, they still are drop-in replacements (you need to slightly trim the plastic, but that's all), but they operate on different principles. Still, they're the same light pattern, just more light. A full replacement of your lights is about $80 on amazon.
I do believe these are the two you'd buy (2x each), but don't quote me:
Amazon Amazon
Amazon Amazon
There are a lot of options. Do your research.
Old 01-15-2019, 07:08 PM
Tsumi
Tsumi's Avatar
With the amount of time you spend posting and reading and not buying a C5, you should know the answer to all of this already.
The following 2 users liked this post by Tsumi:
FX VETTE (01-16-2019), SG Lou (01-25-2019)
Old 01-16-2019, 07:53 AM
grampi50
grampi50's Avatar
My goal is to know more than I will ever need to know about the C5 before I buy one...
Old 01-16-2019, 10:36 AM
Tsumi
Tsumi's Avatar
Gas cars will be outlawed by the time you think you know enough to buy a C5.
SG Lou (01-25-2019)
Old 01-16-2019, 12:03 PM
runner140*
runner140*'s Avatar
Old 01-16-2019, 12:12 PM
grantv
grantv's Avatar
LOL!!!
Old 01-16-2019, 01:18 PM
98C5P
98C5P's Avatar
The stock headlights are ridiculously dull and do not have the throw of modern headlights....I installed a set of radioflyers Bi-Xenon ACA's on a customers car ( my old Z06)...well!! Low beam is great and the Hi-4 is amazing....
I did have a cheap set of LED's stuffed in the stock housing for low beam before I sold it, it was upgrade over stock, decent light output, just wont be as focused/crisp as a good ACA setup. Stock halogen reflector sort of scatters light a bit.
OP- Have you test driven a stock C5 at night?
You can upgrade bulbs like others have suggested on the cheap, or pay to play and spend some cash on ACA's.
Old 01-16-2019, 01:56 PM
dleibman
dleibman's Avatar
cut the guy a break, he is just asking a question. And I guess you know all there is to know about vette !!!
Old 01-16-2019, 03:23 PM
BlackHellcat
That's quite silly
grantv (01-16-2019)
To Questions about aftermarket headlights
Old 01-16-2019, 03:37 PM
grampi50
grampi50's Avatar
Originally Posted by BlackHellcat
That's quite silly
Nothing silly about knowing as much as possible about a big ticket item before making a purchase...what would be silly is not knowing enough before buying...stupid, actually...
Old 01-16-2019, 03:38 PM
grampi50
grampi50's Avatar
I have not, only during the daytime...
Old 01-16-2019, 03:40 PM
grampi50
grampi50's Avatar
I highly doubt gas cars will be outlawed by next spring...
Quick Reply: Questions about aftermarket headlights
