A-pillar trim alignment- t-top front lock rubbing
Old 01-15-2019, 02:01 PM
pmr2000
pmr2000's Avatar
Default A-pillar trim alignment- t-top front lock rubbing
Any tips on getting this aligned so the locks don't hit? Replaced it last summer with Wilcox supplied pieces, look good compared to old. Originals were deteriorated at top so can't tell if they were rubbing also.
See attached should the trim wrap around or cover the this lip you see if the photo between the weatherstripping and the trim?
Old 01-15-2019, 03:08 PM
pmr2000
pmr2000's Avatar
Old 01-15-2019, 03:14 PM
pmr2000
pmr2000's Avatar
photo attached
Old 01-15-2019, 07:07 PM
DUB
DUB's Avatar
Received 2,713 Likes on 2,321 Posts
It physically cannot wrap a round the pillar. It is pretty much going to end up looking like how you have it now and YES...the T-top latch is known to sometimes conflict with it and that may require NEW holes beign drilled in the pillar post .
DUB
Old 01-15-2019, 07:18 PM
pmr2000
pmr2000's Avatar
Great at least its probably installed correctly I was able to get all the screws back in. To clarify I was wondering if it should cover the lip that is inbetween the rubber and trim, it kinda covers it on the top and bottom but not the middle.
So I guess that probably is why the original got chewed up at the top?
Old 01-17-2019, 06:16 PM
DUB
DUB's Avatar
It being chewed up at the top has nothing to do with why it is not up against the pillar in the middle. That is the part itself. Modifications or adjustments to how it is installed may be required to get that gap to go away and look like the top and bottom.
DUB
Old 01-18-2019, 09:13 AM
pmr2000
pmr2000's Avatar
Thanks, I will consider reinstalling and modifying....or just leave the tops off year round has been my temporary solution!
Old 01-23-2019, 06:46 PM
kansas123
kansas123's Avatar
Looks one h(** of a lot better than mine ever did! Good going!
To A-pillar trim alignment- t-top front lock rubbing
Quick Reply: A-pillar trim alignment- t-top front lock rubbing
