Jacking Pucks
Old 01-15-2019, 03:53 PM
ILXgirl
ILXgirl's Avatar
Default Jacking Pucks
Does a jacking puck do anything other than provide a smooth, solid surface to protect the underside of the car?
Old 01-15-2019, 04:03 PM
LarryFL
LarryFL's Avatar
Keeps lift arms away from the rocker panels, yes, but also forces them to put the contact points in correct spot.
Puck?? I don't need no stinking pucks!
Old 01-15-2019, 05:15 PM
Maxie2U
Maxie2U's Avatar
Received 4,153 Likes on 2,250 Posts
Originally Posted by larryfl
keeps lift arms away from the rocker panels, yes, but also forces them to put the contact points in correct spot.
puck?? I don't need no stinking pucks!
^^^^^^ complete agree.
Old 01-15-2019, 05:43 PM
mbaessler
mbaessler's Avatar
Do the dealers use these pucks?
Art17 (01-17-2019)
Old 01-15-2019, 05:47 PM
Woodson
Woodson's Avatar
Received 1,365 Likes on 790 Posts
If they are mounted to the car they sure do.
The following 2 users liked this post by Woodson:
Art17 (01-17-2019), orca1946 (01-17-2019)
Old 01-15-2019, 05:50 PM
mbaessler
mbaessler's Avatar
Are they already attached to the car? I will go look at the car in the garage.
Old 01-15-2019, 05:51 PM
Woodson
Woodson's Avatar
No, you have to buy them and pop them on and forget about them. Don't bother with the ones you have to carry around in the storage bin and hope the dealer uses.
Art17 (01-17-2019), mbaessler (01-15-2019)
Old 01-15-2019, 06:00 PM
BEAR-AvHistory
BEAR-AvHistory's Avatar
Does the car have a single point where you can lift the whole front or rear end?
Art17 (01-17-2019)
Old 01-15-2019, 06:20 PM
Oneslackr
Support Corvetteforum!
Oneslackr's Avatar
From the 2018 owner's manual.
The following 2 users liked this post by Oneslackr:
Art17 (01-17-2019), V Vette (01-16-2019)
Old 01-15-2019, 06:35 PM
JMII
JMII's Avatar
Received 2,025 Likes on 1,349 Posts
The rear cradle requires a long, low jack. The front cradle is difficult if not impossible to reach unless you drove onto ramps first. If you do use the cradle positions just make sure you are on the aluminum sub frame and NOT the black suspension (leaf spring).
Or make your life super easy and get a Quick Jack Lift.
The following 2 users liked this post by JMII:
Art17 (01-17-2019), BEAR-AvHistory (01-15-2019)
Old 01-15-2019, 07:58 PM
BEAR-AvHistory
Thanks both for the info. Have a low jack & wood ramps made from 2"X10"s for my current cars. When I saw the picture in post #2 was looking to see if it had center line pickup points for a floor jack.
Art17 (01-17-2019)
Old 01-16-2019, 12:58 PM
Mayor111
Mayor111's Avatar
Received 1,955 Likes on 941 Posts
$4 for each hockey puck and a $1.50 for each screwable eye bolt is all you need - make your own (4 of them) and toss them in the back of the car when needed. Took me 15 min to make and I have been using the same set on 4 different Vettes for almost 3 years now...
Old 01-16-2019, 03:08 PM
~Stingray
~Stingray's Avatar
St. Jude Donor '17, '19
I bought this set from amazon so I didn't have to worry about making them and they stay in.
Amazon Amazon
NOTE: I have side skirts and they are required to get the car up. however, the gaps in the skirt are smaller than the plate on the jack for the back. So when i jack the car, I put a board on the jack and it touches the puck before anything else and barely barely clears the side skirt. The front, the gap is big enough that I can allow the plate to tough the puck directly as the cutout for the front jacking area is bigger than the rear. So if you want to avoid doing this, I would buy two sets and stack them.
Old 01-16-2019, 03:28 PM
Kevin A Jones
Kevin A Jones's Avatar
Received 11,695 Likes on 5,594 Posts
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Or just buy these which easily clear the GS / Z06 skirts and you don't have to worry about using a board or stacking pucks and the risk associated with it.
The following 2 users liked this post by Kevin A Jones:
JMII (01-16-2019), Woodson (01-16-2019)
Old 01-16-2019, 04:18 PM
~Stingray
~Stingray's Avatar
And where did you get those?
But those are not leave-in correct?
Old 01-16-2019, 04:49 PM
Woodson
Woodson's Avatar
the website is on the puck.
Old 01-16-2019, 05:34 PM
Widgeon5
Widgeon5's Avatar
>>>But those are not leave-in correct?<<<
They are not meant to be left in full time, and in my opinion extend too low to be safely used that way. But they have a provision to be tightend up securely if, for example, you wanted to drive to a dealer with them installed.
To Jacking Pucks
Old 01-16-2019, 05:39 PM
Kevin A Jones
Correct, as I don't want leave-in pucks as:
#1 - 90% of the time my C7 is going to be jacked, I'm going to be jacking it and it only takes me about 2 seconds to twist in a puck.
#2 - the 10% of the time when someone else may be jacking my C7 they are going to be smart enough and responsible enough to install the pucks I supply them or they will not be jacking my C7.
#3 - I don't want to take the chance of a 'leave-in' puck flying loose and damaging the side of my C7. Happened to a buddy of mine.
Old 01-16-2019, 05:48 PM
Woodson
Woodson's Avatar
#1 - 90% of the time my C7 is going to be jacked, I'm going to be jacking it and it only takes me about 2 seconds to twist in a puck. True.
#2 - the 10% of the time when someone else may be jacking my C7 they are going to be smart enough and responsible enough to install the pucks I supply them or they will not be jacking my C7. You have more control over your service department than I do.
Mine snapped in super tight and secure. Not saying your buddy's didn't happen but I simply can't picture this happening to mine.
Old 01-16-2019, 09:32 PM
Kevin A Jones
He actually made his, however I'm not taking a chance on leaving any pucks installed, whether home made or manufactured.
Quick Reply: Jacking Pucks
