Radiator Fan Switch
Radiator Fan Switch
Hi Guys,
My radiator fan switches on at around 185 Degrees Fahrenheit, which means that it is basically working constantly. The switch is an AC Delco D1852B - the switch is new, as the the coolant temperature sensor and the thermostat. I believe that the radiator fan is meant to switch on at higher temperatures (~210 or more Degrees Fahrenheit). Does anyone know how I could correct the issue so that the fan switches on the at temperatures that it should. Is this a switch issue, or something else?
Any help would be greatly appreciated.
Cheers,
Ved
Cheers,
Ved
Hi Guys,
Cheers,
Ved
Cheers,
Ved
How have you arrived at what you believe the temperature? What year? For most years that switch is used for the AUX FAN or maybe to 'over-ride' a primary fan for other years. Year and how wired dictates how that switch is used!
I have that same CTS in my '84, and it cycles my radiator fan on and off just fine. I haven't tested the on-off temps of my sensor with an accurate thermometer, but the specs I've been able to find list the on-off temps at 215 on and 200 off. All specs have a +/- tolerance, but your reading seems a long way off those numbers. As WVZR-1 asked,"how did you determine your numbers?"
