Inexpensive track tire
I haven't tried them for the track, but I had them on my 2013 Mustang GT. They are pretty abysmal, both from a straight line perspective and a cornering perspective. Just to give you an idea, I think the PSS are not that great for putting down the power of our Zs. Having said that, when I went from those ventus v12 evos to the PSS on my Mustang I thought "holy **** this is the stickiest tire on the planet!". They're serious garbage.
I put a set on my CTSV, to replace the PS2's. They were a noticeable step down on the track, but they were a fine street tire. They wore a lot slower than the PS2's too.
if you want a high performance track tire, look elsewhere. If you want a reasonable tire that saves you some cash, it's not a bad choice. I recall thinking that they were 85% of the tire for 50% of the price (it has been a few years... ). I can't comment on how they might be on a Z06.
on track, if you want to be the fastest and be able to push the car (chassis and drivetrain) the hardest, I agree. But a little less traction just changes the way the driver reacts....you can still have a blast on track with slightly lower performance tires...or even a lower performance car.
(ok I realize that I am gonna get myself flamed now, but I am dressed for it....)
rwheelz (01-17-2019)
Received 8,928 Likes
18 inch wheels will fit over the CCB brakes there are plenty of people running 18s on their C7 Z06s and GSs. The tire itself doesn't look like it could hold up well doing dry track duty. It might be OK when you are driving in the rain. Most street tires are not designed to be run at high tread temperatures since even in very hot high ambient temp areas the tread temps don't go above 135 to 140 degrees. The Michelin PSS ZP tires seem to perform very well on track where tire temps can reach above 200 degrees. The PSS ZP operate at 190 degree (their max grip operating temperature) at 26 psi cold pressure.
Don't think because a tire has street cred that it can stand up to track duty. I tried a set of Nitto NT05 street tires on my C6Z. They had a great street cred with all sorts of people claiming how great they stuck and handled. On track they didn't last more than 10 minutes before they got so greasy it was like driving a car on wet pavement instead of dry pavement. When I went back to the poorly rated GY EMT ZPs they could handle 20 minute sessions and handled very well.
Bill
Bill
IInexpensive track tiren[b=left]Inexpensive track tire[/b]
These words don't usually belong in the same sentence.expensive track tire
Bill
Sr.Random input generator
For track tires, my bar would be NT01s; I'd not want to use anything with less traction on a Corvette.
On a Miata, sure, you can go nuts. On a Corvette, though, even OEM suspension will feel too stiff with lower traction tires, and you'll be hunting lines in corners; why bother?
Plstxmd (01-21-2019)
When you get way off in traction, you also happen to change the character of the car in terms of handling. Our cars already have overwhelming torque as is, and much less traction would make the car much more sketchy, and 'nervous'. In short, I don't think it'd be as fun as you're suggesting : )
or maybe I just drive like a sissy-boy.....
One of the things I've forcefully learned in the recent years is that suspension setup and the tire traction really needs to be very closely matched. When the tires have too low traction, it feels like you're driving on ice, the rear snap-oversteers and skips track, the front seems to have terminal understeer, which exacerbates the loss of traction from the cheap tire, and it's no longer a fun car to drive. When you use tires that are too much for your setup, then the car starts leaning everywhere, feeling like a boat, slowing down the chassis responses, and rubbing your confidence where you need it most, making you think you must be very close to the limits of the car (even though you're not necessarily there). In short, in my opinion, driving the car with much lower traction than designed, and having just as much fun is a myth.
I'm sure you can still have fun with such tires, don't get me wrong, but I personally don't think it could ever come close to the fun of driving a very well balanced car close to its limits, since it won't be : )
(Note: My bottomline is, sure, go with lower price, like NT01, but not necessarily lower traction)
the 18" wheels and tires fit on a Z06 and they are much cheaper. the track slicks are cheaper too. there are some great posts by Bill Dearborn on here about this setup.
Bill
Bill
Thanks
watch out y'all Ricky Bobby over here pullin some G's. just messing with you man I am the same way a bit. be safe out there. when you are moving at a high velocity delta to other cars you will not be able to react to things in time as if you were just taking it easy.
As far as 18 inchers go, I personally just can't support that. I think it makes the vette look like an old Chevelle, with the small wheels and high side wall tires. If you're JUST using it for the track, I guess that's ok, but personally I prefer to stick with 20s and would only drop down to 19s if I were getting some wheels like these:
19" full carbon fiber wheels with titanium lugs from Carbon Revolution
Toddiesel (01-18-2019)
Whatever you do, NEVER cheap out on tires. They are the contact patch between you and the road and the most single important component of your driving experience.
The C7 Z06 has a lot of low end grunt in a relatively light car. You should focus on being able to put the power down. The only way that happens is with super sticky rubber with a wide contact patch. If I were you, I would think about Michelin PS4 tires. Tried and true. Bit more money upfront with huge rewards.
