stock O2 sensor routing
I'm looking for a pic of how the upper O2 sensor wiring is routed. I have an LS3 and am considering installing Z06 manifolds, but the O2 sensor is farther downstream on the Z06 so the sensor won't reach without extensions or untaping wires. It looks like both engines use the same sensor, so I'm just wondering how it's done on the LS7 so maybe I can get some ideas. Thanks
Really not much to see. connect the extender harness the the oem connector near the coil packs, run the wiring towards the firewall and downward behind the engine and connect the the O2 sensor. Just make sure to secure the harnesses away from the exhaust and/or firesleeve as needed.
