[C2] 1965 327/365 Engine
1965 327/365 Engine
I have toyed with the idea of putting a period correct engine back in my '65. I have gotten a line on a rebuilt 327/365 HP. My car was origianally 300hp with A/C. Now has a 1973 350 in it.
Wondering if I would run into any issues considering this 327/365 engine. Thinking it should be a straight swap in. Would there be any issues using a 2101 Edelbrock intake with a block that uses oil can vapor seperator?
Here are a few pics of the rebuilt engine.
Thanks for any input you might have.
Received 6,927 Likes
2015 C2 of Year Finalist
unless there is something wrong with your 350 I don't see any advantage on swapping. whats the build details on the engine
Received 2,126 Likes
With my understanding of what you said, you should not have an issue as long as you have the manifold boss drilled for the oil fill tube. Dennis
smacota1 (01-16-2019)
Those heads have been substantially ported on the exhaust as well. I don't know that I wouldn't do it as I like hot rod motors. But don't pay resto' money for it. Pay hot rod money. Where hot rod parts aren't worth what resto parts are.
2020 C1 of the Year Finalist - Modified
Not that it couldn't be changed, but why a downdraft tube for the crankcase ventilation? I may be incorrect, but on my '64 327/365 I kind of remember the ventilation was run up to the bottom of the air cleaner... Maybe it would show/sell better as a true 327/365 with the correct ventilation and the previously mentioned oil pan and and valve covers..."Caveat Emptor"...
Received 1,843 Likes
Would you be interested in a restamped '65, 870 block. L 79 engine. 15K on rebuild. Almost complete engine except for carb and distributor? Engine is in SW Ms. Easy drive to get it.
If it's dated C 17 65.... with a "two digit" year designation, that's an indicator of a Tonawanda NY cast block.
A Flint cast block would have a single digit year, C 17 5.
Both would be 870 blocks.
Chuck in the one picture you can see the oil pressure plug above the timming cover suggesting its a flint block
C1 of Year Finalist (appearance mods) 2019
I've consider purchasing a 350HP or 365HP mid year, but wondered if todays 91 octane (best I can get locally) has enough poop to handle these higher compression engines (11:1 and 11.5:1 I think)? The 350HP with hydraulic cam is of more interest to me. Thoughts on 91 octane and these engines?
BH
BH
64's Rock!
BH
BH
64's Rock!
Patrick
Dreaming60’s (01-17-2019)
Rob_64-365 (01-17-2019)
I don't think you'll run in to any issues, but you'll have to do some work to get it looking like a real period correct 365 hp motor. Valve covers, PCV system, idler pulley, large capacity oil pan, fuel pump, chrome oil fill tube, chrome dip stick, and water pump with bypass. Manifold and carb of course, but you said you'd use parts you've already got. Just depends on how far you want to take it.
Patrick
Patrick
