Methanol substitute?
So my first road trip with a meth dependent car got me thinking, what’s a good emergency meth substitute? Maybe not perfect but better than nothing just to get around on as even “normal” tickles the boost a bit....
Washer fluid? Rubbing alcohol? Vodka? Nothing denatured I believe, so no Home Depot paint aisle alcohol.
Thoughts?
Thoughts?
Heet, windshield wahser fluid or even just water depending on how much you are spraying.
Or just don't floor it .
winters97gt (01-20-2019)
You only use meth when in boost so it should not be an issue because you won’t use meth on long trips unless you drive like a lunatic. Yellow HEET, available at most auto stores, is a good substitute.
Thoughts?
Thoughts?
Meth last a long long time .I typically fill up a little at each oil change. Worryimg about it would be like packing oil to change your oil on the trip
