Engine cap?
Old 01-19-2019, 10:33 AM
shipahoy
shipahoy's Avatar
Default Engine cap?
Please help me identify this engine cap on my 04 Z06.
is the one circled in white the manual transmission cap?
Thank you.
Old 01-19-2019, 10:43 AM
neutron82
Support Corvetteforum!
neutron82's Avatar
Received 1,261 Likes on 1,056 Posts
clutch fluid reservoir
Old 01-19-2019, 10:48 AM
shipahoy
shipahoy's Avatar
Thanks, that's what I thought.
Old 01-19-2019, 12:20 PM
grantv
grantv's Avatar
Manual tranny is at back of car, connected to the rear end.
Old 01-19-2019, 12:45 PM
Tsumi
Tsumi's Avatar
Manual transmission fluid and clutch fluid carry two very different meanings
Old 01-19-2019, 01:50 PM
shipahoy
shipahoy's Avatar
Thanks, I'm learning.
Old 01-19-2019, 06:11 PM
Velocity_Vette
Velocity_Vette's Avatar
As mentioned your transmission is at the rear of the car attached to the differential. There is no real way to "check" the transmission other than lifting the car (ensuring it is level) and removing the fill plug (it's the same as the transmission temp sensor; that's where fluid goes in). The service manual says that manual transmission fluid requires no service but ideally you should change the fluid, even on lower mileage cars. Replacing +15 year old transmission fluid does wonders for a lot of shifting issues. If you're unable to do it or concerned about doing it properly you can likely find a Corvette specialty shop in PA that will do it at a competitive price compared to the dealer. Ask the local clubs who they take their car to.
Old 01-19-2019, 09:40 PM
shipahoy
shipahoy's Avatar
All I wanted to know was the name of the cap. But thanks for the information.
To Engine cap?
Quick Reply: Engine cap?
