'59 Turn Signal
'59 Turn Signal
Dear Members,
Somehow one day driving, my signal lever got loose moving around a little bit. I took the steering wheel off and look at the turn signal cancelling cam. It looks like nothing is broken. However from the picture one below it looks like there supposed to be a machine screw thru the hole to hold the cam in one place.
Below is picture of when I take out the cam. Should I go to like a hardware store and buy a simple phillips machine screw type or is there a special screw for this?
Thank you in advance for your help.
That is a large smooth-shouldered screw to let the cam move easily. Repro vendors have them. Don’t use regular hardware store screws. You will see several pictures of that screw installed and by itself in this document by a forum member. Technically its called a pivot bolt and can be purchased here:
https://www.zip-corvette.com/56-62-t...ivot-bolt.html
kdnguyen (01-20-2019)
The signals should return to center automatically once you have that pivot bolt installed....read that attachment above to see how to set up and troubleshoot the signals...
I wonder where yours went to
Hi Frankie,
Should I go ahead and order the two small springs since mine looks so old? I bought the car two years ago and don't want to put back together and the lever don't return to normal. Should I also buy that C shape rod too?
Why not. ? They’re not a lot of money.
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
There is a washer on that pivot pin as well. If you don't install it, it will bind and not cancel cleanly. Ask me how I know!!!
It's not shown in the attachment that Frankie posted.... but you'll want that too.
The lock washer is included with the Zip Corvette pivot bolt.
Tether Man
Received 2,014 Likes
2019 C1 of Year Finalist (appearance mods)
Shipping will be $30.00...............I'm sorry.............
I had to re tension the cancelling spring, clean and lightly lube mine to get it to cancel consistently...........Where did the bolt go?
FTF
He can have them on hand if needed, but IN MOST CASES, I'm a fan of leaving original parts in place unless I KNOW there's a problem with them...
[ yt] 9N8WZ1HVSz8 [ /yt]
I hope this works and shows the video. Watch this video before you do anything. It shows you step by step what you have to do. Yes as others stated you are missing the shoulder bolt and washer
Pro Mechanic
Received 1,302 Likes
2023 C1 of the Year Finalist - Modified
Interesting video. It did not work for me and here's why; He is correct in that the housing gets to be oval shaped on the horizontal. The problem is; there is oval then there is OVAL. Mine would not tighten down and stop moving even with the cam trimmed, and required a shim behind the back side (left) of the cam. When I reinstalled the steering wheel it looked like crap because the whole assembly was off to the left enough to be very noticeable. The only way to correct this was with a sheet metal shim (I think it was .015 to .020") on the right side of the column. When put together it centered nicely, looked good with the wheel on, and was tight enough to not move when using the turn signal. Problem then was that they did not cancel when the wheel came back to center. Here was the issue; The housing becomes oval but the turn signal assembly/casting stays the same. The little post, that sticks out the back of the assembly and inserts in the hole of the switch, was now rubbing on the left side metal portion of the switch jamming the mechanism just enough to stop reliable cancelling. I had to file off about 1/3 diameter off the left side of that little post casting and now everything works sweet. I found all this out the hard way.
