Need Help. Lifter issue I this Bad?
Old 01-21-2019, 03:25 PM
ajd3rd
ajd3rd's Avatar
Default Need Help. Lifter issue I this Bad?
I'm changing the lifters on my 96 LT1 and on the side with the noise I found a lifter whose roller is kinda beat up. I've attached a few pictures. Is this a major problem?
I don't think I have the ability to pull the cam shaft and I'm wondering if this will be ok with just a lifter change.
Thanks
Old 01-21-2019, 04:02 PM
KyleF
KyleF's Avatar
It certainly doesn't indicate good things.
Might need to see if you can borrow one of
THESE THESE
Old 01-21-2019, 04:09 PM
jgalfo
jgalfo's Avatar
that engine needs to come apart. it's hard to diagnose just from looking at that lifter. I want to see the cam too. pushrod rocker arm and inside of the oil filter also
Old 01-21-2019, 04:32 PM
ajd3rd
ajd3rd's Avatar
The cam doesn't look as bad from what I can see both with a flashlight and borescope. I finished pulling all of the other lifters and they're all smooth with no marks. Pushrod looked ok but I will pull it again and also examine the rocker. Not sure what to do at this point. If the camshaft needs to come out then I'll need to send it out to be done.
Old 01-21-2019, 05:20 PM
ajd3rd
ajd3rd's Avatar
I pulled it apart again. The rocker looks ok as well as the pushrod. Both do not appear to be damaged. I looked again at the cam it definitely has some marks but it's no where as bad as the lifter. Not sure what to do from here or what caused this. Any further advice would be greatly appreciated..
Old 01-21-2019, 07:59 PM
Joe K
Support Corvetteforum!
Joe K's Avatar
2022 C4 of the Year Finalist - Unmodified
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (appearance mods) 2019
Default Jmho
Just replacing the lifter is a bandaid. It will just destroy the new lifter in a short time. A worse case would be the cam breaks and who knows what else. Sorry but you, at the least, need a camshaft and lifters.
Old 01-21-2019, 10:33 PM
zachaeous
zachaeous's Avatar
Old 01-22-2019, 12:24 AM
84 4+3's Avatar
Received 1,372 Likes on 1,061 Posts
as well. Better to be safe than sorry.
Old 01-22-2019, 07:41 AM
84 4+3's Avatar
Originally Posted by ihatebarkingdogs
Not one of the people above that are advocating changing the camshaft have SEEN the affected cam lobes. Neither have I. But you say "not as bad as the lifter roller" and there are only two affected lifters and lobes. Roller lifter cam lobes are very tough. I can't tell you why two rollers fretted like that, but there are several possibilities that wouldn't necessarily affect the cam lobes. You say you don't feel confident that you can change the cam yourself. You are looking at a lot of money to have a shop or specialist do it for you. Personally, I think its worth the gamble to put lifters in it and run it. What ever prompted you to look at the lifters this time (noisy rockers?) would probably happen again to alert you to the repair didn't last. If you don't intend to keep it too much longer, I'd fix it and drive it. If it gets noisy again, you cold consider selling it at a reduced price reflective of what the repairs would have cost you.
I had a very noisy lifter in my DD S-10. They were Chinese white-box roller lifters that I put in it when I reconditioned the engine 125K miles earlier. When I pulled the bad lifter, the roller's axle pin had come loose and had broached the side of the bore to a depth of about 100 thou. Two other lifters also had loose pins, but hadn't gouged the bores. I replaced all of them, and I'm still driving it 10,000 miles later with no further lifter noises or issues. My point is that I know there is some damage, but I chose to ignore it. So far, I made the correct choice. The alternative whas to replace the engine. Not going to happen on a 29 year old truck with 345,000 miles on it.
There's more to deciding what you need to do other than the damage. You could be facing $3,000+++ to replace the cam. You could also replace the lifters yourself and drive it for years with no further lifter problems. I know what I'd do.
I'm not disagreeing with you. But after having two cams go flat on me with seemingly less damage, I trust nothing anymore. The one cam I almost reused the lifters because they were fine but the amount of metal in the oil made me chuck them.
Chances are the roller itself had a metal defect and it pitted and broke down like that for whatever reason. Is the cam fine? Probably. But I've had it go the other way twice now. If you can pull the oil pan, see if there is metal shavings in the bottom. If not, I'd probably run it without too much worry.
Old 01-22-2019, 09:15 AM
pacoW
pacoW's Avatar
How many miles, and what are your plans for the car?
Old 01-22-2019, 10:01 AM
sstonebreaker
sstonebreaker's Avatar
have you checked the valve springs? A weak or broken spring could be allowing the lifter to bounce.
Old 01-22-2019, 10:07 AM
drcook
drcook's Avatar
Finalist 2020 C4 of the Year - Modified
With cratering and pitting like that, it is a certainty that metal fragments have hit the oil. Has it got to the main and rod bearings ? Who can say. Did it get to the cam bearings ? Once again, who knows.
Take a sharp pencil and stick it down the lifter bore and feel the camshaft lobe. Don't break it off of course, just use it to feel the surface. Graphite won't hurt and you would be surprised at how a pencil will transmit roughness back to your fingers. I used this method years ago when feeling surface finishes when I did precision machine work. After a while, you get a "feel". In this case you will be able to feel if there are raised deposits on the cam lobe, cratering, etc.
Old 01-22-2019, 10:10 AM
TravisSchoech
TravisSchoech's Avatar
can you get a pic of the affected cam lobes?
Have you looked a the other lobes? (the ones NOT making noise)
I've seen lifters go south like that from excessive spring seat pressure, AND I've seen it from loose components (collapsed lifter, loose rocker, bent pushrod)
Old 01-22-2019, 10:29 AM
VikingTrad3r
Oil Producer
VikingTrad3r's Avatar
Received 2,262 Likes on 1,446 Posts
intrigued and subbed for learning
Old 01-22-2019, 02:59 PM
bjankuski
bjankuski's Avatar
I would think that the oil filter would have trapped most if not all of the small particles before they did any damage.
I have seen many cam lobe failures and most of the time the engine is fine.
Old 01-22-2019, 04:04 PM
drcook
drcook's Avatar
Hence the who knows. The only way to know is to run it or take it apart. If it is just a locally driven car and not a daily driver, then drive it. Hopefully the particles are trapped in the oil filter, or sitting at the bottom of the pan.
After getting it fixed, I would change the oil twice. Once with el cheapo oil and a filter to just start it up, run a bit and then change it out again with good oil.
Old 01-23-2019, 04:40 AM
ajd3rd
ajd3rd's Avatar
Thanks for the many replies. It’s only one lifter/lobe that’s damaged. The car has 60k miles and I commute in it in the summer about 150 miles per day.. It’s a convertible and in nice shape. I talked to a friend of mine who owns a shop and it looks like he’ll do it. They do a lot of engines and are known to be good. I’ve done a few engine rebuilds years ago but I don’t really have the time or patience to remove all the stuff up front and lift the engine to get the cam out. I’ll post an update once he looks at it.
Many thanks for everyone’s help.
To Need Help. Lifter issue I this Bad?
Old 01-23-2019, 04:46 AM
ajd3rd
ajd3rd's Avatar
One more thing. Assuming he says the cam needs to be changed does it make sense to just replace it with a stock cam. I don’t want to need to change the tune but a little more power would be nice.
Old 01-23-2019, 05:52 AM
84 4+3's Avatar
I've read you can get away with a hot cam on the stock tune. Take that for what it's worth.
Old 01-23-2019, 11:18 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
GM claimed that on their pkg yrs ago. You can...but its better with one.
Really they did a good job with the LT4 pkg offering that cam with. Nice pkg that passes smog. Too bad some idiot designed an igition system next to water and a major heat source.
had they stuck a regualr distributor on them I bet their demand would be higher.
Quick Reply: Need Help. Lifter issue I this Bad?
