Doorguide Rubber Socket Thing
Car is an 89. What do you call the rubber socket thing on the B pillar that accepts the metal door guide pin? I can find the doorside pin in my FSM but not the rubber socket bit. Mine are rock hard and I would lke to replace them if available and if they will help soften the door slam.
Door receiver Lead, and the padded part of it is normally Fairly hard
https://corvetteparts.com/item/recei...oupe-1984-1996
Thanks, s carter. If it is normally that hard, then I'll pass. Did you see the price?
