[C1] Convertible Top Installation
2023 Restomod of the Year Finalist
Just got an estimate from a renowned C1 installer for a new convertible top from stayfast material and seems high to me (of course, everything seems high to me anymore). This guy is one of the best I’ve seen and I’ve seen many of his tops. I admit the frame is going to require some straightening work. What do you think a fair price would be?
Popular Reply
01-23-2019, 09:09 AM
Okay, the top is $900, it’s kinda special and the color I like so that doesn’t bother me too much. He’s quoted $750 to straighten and adjust frame to windows, $1250 plus $250 for pads to install the top, plus $225 for all new rubber and a rear bow mohair weatherstrip for $100. Making the total approx. $3500.
That's too much...
For tear off and install only $550 to $750 labor, plus top kit. If the frame requires straightening, tack strips, or other parts, add on for labor and parts. Al Knoch typically charges $750, plus top, installed at the shows. No framework included.
"Cry once, buy once"
You don't provide a number so there is now way to gauge if the cost makes sense...
Even if its $1,500 you can save by getting one of those $2,000 paint jobs I hear so much about....
That's too much...
The following 6 users liked this post by Frankie the Fink:
59BlueSilver (01-23-2019),
Dreaming60’s (01-24-2019),
Loren Smith (01-23-2019),
mark6669 (01-24-2019),
mike coletta (01-23-2019),
and 1 others liked this post.
Received 6,530 Likes
C2 of Year Finalist (track prepared) 2019
Really? C1 soft tops are that difficult to install?
35 years ago I had a new canvas top installed on my '54; it cost ~$300. Admittedly not the same as a '59 top, that's my single data point which makes me cringe at prices I'm reading about.
Tim Dearth (11-22-2023)
The number quoted was more than double my tippy-top estimate assuming a meteor had hit the cockpit.
Shop around - there are a few tricks but its not rocket science...
You have a good data point with Mike C's numbers - he installed my top and a hundred others over the years I'll bet.
I would like to have Al Knoch install it, he attends a couple of shows in Dallas per year. I don’t know how difficult it is to schedule it with him.
Just talked to Al Knoch, for the next year they’re only doing Tennessee and Florida, so am actually thinking about trailering 600 miles to El Paso. Seems like overkill to me but better than $3500.
Quite the coincidence 59. I need to get a new top on my '57. I've been quoted $2,500 by a very highly recommended guy here in Dallas. Sounds like there is quite a variance in pricing, and probably quality.
Nick
Nick
I have installed three tops on my car. Using written instructions, they didn't have video back then.
It is not hard if you take your time and I strongly urge having helper to get it right.
One problem with many professional installers is they put the top on drum tight, which is way too tight, but most owners expect a top that tight even if it wasn't that way from the factory, so the installer put it on too tight. And too tight a top will bend the rear latches and pull the top header away from the windshield, even if you side posts are not broken.
The most important thing is making sure the bows are in correctly position, using the pads, you don't want to necessarily use the old pads as templates without first verifying the dimensions of the bows from the header.
Two newby guys can easily do it in two hours. Take four hours and watch the videos a couple times. Or take more time,and remove and paint the bows, or get them powder coated, and straighten any bends over the doors, etc.
The only special tool you really should ahve is a staple gun. I even used the tacks supplied with the tops, the first two times,as I didn't have a staple gun in 1974 and 1980.
Doug
Doug
Just for the record, it takes Al Knoch's guy over 4 hours, with NO frame work, and he has been doing it all of his life.
Doug
Doug
Doug
I am sure you can find something on youtube. Definitely have a helper that watches the vid too, walking back and forth around the car, doing it by your self, is a PITA.
Doug
Doug
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
$3500? Trailering 600 miles? Holy "Corvette Premium" Batman!
Maybe I'm spoiled.. But here in SoCal, there are a lot of really good craftsman auto shops.
My frame and rubber was good.. $500 to install a stayfast top. It took him 6-7 hours and is not an easy job.
Still.. Even $500 for an 8 hour job is over $60/hr. How can someone justify $3500????
Look for a shop without the word "Corvette" in it's name. Soft tops of the era were all similar!
