Help
Help
My situation:
My brand new, 6.8 liter LS2 with cam, hedders, and D1 Procharger failed on the dyno. But, that's another story.
For the past 5 months I have, by working a few hours a week, pulled the engine, had it rebuilt, reinstalled it, along with some additional goodies, all with no help, inside my small garage. It was a royal PITA.
Finally, after checking, re-designing a few things, checking again, she fired right up on Saturday. The only issues, at first, was a "Service Active Handling" alert in the DIC. This did not seem to effect anything on the way the car drove. So, after approximately 50 very easy miles, I got a P-0156 CEL, which meant Bank 2 sensor failure.
My questions are:
1. What would cause the active handling issue? Nothing was disconnected concerning the brakes.
2. What sensor would have failed giving me the P-0156 code ?
Even thought the engine seems to be running flawlessly, I do not want to drive it until I resolve 1 and 2.
Thanks in advance for your help.
My questions are:
AHS will throw with tire air pressure being off, steering sensor being off (did you disconnect the steering coupling in the engine bay?), and a few other things but thats where i'd start with...
Yes, the steering coupling was disconnected to accommodate the extraction and installation of the engine. Not sure if it was re-aligned to the original location. May have been clocked somewhat.
Question, How do I correct this?
Thanks
Thanks
Do you have access to a tech 2 or a tech 2 clone? You need to read out the sensor "zero" and reclock it correctly. Its either that or guess and check one full rotation one way or the other - which I really don't recommend since the airbag connector reel in the steering wheel really doesnt like being uncentered. The tech 2 will also allow you to set the steering sensor to zero but that is also a bandaid - get the reading, turn the wheel to the right position - then reinstall.
I went back and checked the steering shaft coupler. I assumed that the shaft had splines on it and perhaps when I reconnected it, I may have been off one spline. I was wrong as the shaft only has a flat spot on it, and if I had installed it 180* out, the steering wheel would not have been centered. Bottom line, I feel 99% that these items are correctly aligned.
Still searching for a solution/
Its possible its a full 360 out... I got a strange SAH error when my MAF was left disconnected a while back as well. Not sure why it would throw that code but it did.
AH uses the steering position sensor, gyroscope, and TPMS (IIRC).
