1971 Corvette power Antenna
From what I understand I have a 69 that Im going to install a power Antenna in and the radio I installed is not stock its a kenwood I think anyway in the wire harress of the radio theres a wire that hooks up to the power antenna. So when you turn on the radio it makes the antenna go up.
1971 Corvette power antenna
Traced that to kick panel on drivers side. I also have aftermarket radio. Inside kick panel found that fuse.
Also to get the antennas to go up and down the have to be mounted in perfect vertical position.
Thanks
Ted
Thanks
Ted
Received 3,220 Likes
If you have a stock radio and want to run a power antenna-
Here's the solution- less than $20
https://pac-audio.com/catalog/specialty-items/tr-4
