EFI how to route new fuel hose
Hi all
I'm working on a fitech efi and wonder how to route my new fuel hose. Any one have some pointers on that? I dont want to lift my body.
worship79 (02-11-2019)
You can see how mine is routed here: https://www.corvetteforum.com/forums...post1598806948
It has been installed for a bout 16 years. It has always smelled. No leaks, no performance issues, no loss of fuel pressure, but that smell just never went away.
I just received 25' of Cu-Ni tubing yesterday. I will be attempting to route it without lifting the body. I am willing to drill holes in the frame for routing but I have yet to determine which way to go.
I may be starting this project within the next week... depending on how lousy the weather is.
-8 AN Aramid braided PTFE hose from tank to engine for last five years. No smell.
https://www.pegasusautoracing.com/gr...pID=PLUMANFLEX
Use solid line. If not, we will pray for you....
What i read is that the return is too small.
I still am waiting on fitech to confirm this.
I did solid line routing it the same as the original. Using a right angle joint fitting at the bottom of the rear wheel well made it easy.
You can also use OEM style plastic line, easy to bend.
I used this same stuff as well. Really great stuff although expensive. Will outlast hardline!
https://fitechefi.com/wp-content/upl...ons1.11.18.pdf
https://fitechefi.com/wp-content/upl...ructions-1.pdf
There was no way in @#$#% I was going to try to run new stainless lines. I went with Earl's VaporGuard composite rubber.
Sure I'll catch flack for it, but it was REALLY easy to use. I used the stock clamp bolts / screws and these rubber clamp vibration isolator things that were stupid cheap @ HomeDepot. (Chris @ EFI System Pro recommended them.)
If I have to replace the lines in 10 years, so be it. I'll have to replace the Holley Hydramat by then, anyway.
Adam
Adam
ZAKsPop (02-12-2019)
I have been using the stock lines for some 22 years now.....the pressure can be adjusted down to only 30 psi, and I quit turning the reg screw at that point....it runs at ~42 or so.....pump in rear tied to frame rail, under tank....high quality black rubber hose AMERICAN MADE supposedly good for ~200psi? at any rate, I have changed it once or twice through the years.....350 SBC......L98 type injection, LT1 intake these daze.....
I am putting a Holley Sniper in my 72 with a 502. I already have a 3/8 aluminum line in the car which I ran with the body on. I now have to run a return line and have 6AN hose for that. I will piggyback it on the 3/8 line.
