C8 Patent For Active Aero Dynamic Side Body Panel System?
Thanks to the Mid Engine Corvette Forum we have some logical info on the C8 generation.The more I read this patent publication, the more it appears to be applicable to only the front engined Corvette. Whether this is for a C8 ZORA or the next C8 FE, that is the question. The system utilizes the steering system with sensors to calibrate the position of the side front vents behind the front wheel wells being key to this function. The C7 ZR1 has stationary side coves that project far beyond the body surface to create a different air pressure on the side of the car at higher speeds. Tadge Juechter has discussed this at length on the CF Ask Tadge forum section on a Aero question I asked. It makes sense to coordinate the air pressure on the side of the car with the steering wheel position progressively adjusting the side flaps. The only side vents on the C8 ZORA appear to be the side coves at the rear of the doors. Trying to tie that into the steering system seems illogical. The front fenders of the C8 ZORA do not have side cove vents behind the front wheel wells to extract hot air out of the wheel well cavity. Unless these ZORA mule front fenders show otherwise It appears this tech is for a C8 front engine configuration.
The following 5 users liked this post by skank:
Corvette_Nut (02-15-2019),
firstvettesoon (02-15-2019),
savage99ss (02-15-2019),
vettedna (02-15-2019),
Viper (02-15-2019)
This system helps the car turn at high speed. It creates high air pressure on one side of the car with low air pressure on the other side helping the car turn during a high speed turn.
Though Pagani utilizes these flaps for corner downforce and front to rear downforce differentials, this new side blade system for the Corvette is very innovative. See video below for the Pagani.
edved (02-15-2019)
Shaka (02-15-2019)
This is a completely logical assessment to the patent. Unless GM is planning an alternate location for a similar effect, it does not appear to be intended for the mid engine and, as such, further suggests that a revised FE is on the way!
I haven't read the patents.
https://www.motor1.com/news/262241/c...namics-patent/
The Patent Publication is over on MECF. Patent was filed on August 8, 2017; note yesterday's Feb. 14th patent publication date.
https://www.midenginecorvetteforum.c...y-panel-system
I didn’t spend hours studying it. But it looks more like flaps on the side of the car and not necessarily related to the side vents on the FE cars. Idea seems to simply use flaps to create drag on one side of the car to make it pull to that side a little more when steering at speed. This wouldn’t be exclusive to the FE car.
I could be wrong. Patent jibberish is pretty much a foreign language.
Location: Hailing From The Mean Streets Of Irvine, California
Received 4,153 Likes
Great information! It's great to see the Corvette Engineering Team utilizing and employing the latest technology and techniques. Similarly, Lamborghini uses Aero Vectoring to help keep those Raging Bulls stuck to the streets.....
*** Courtesy Of Lamborghini ***
Save The Wave,
Corvette_Nut
Save The Wave,
Corvette_Nut
I did read the whole Patent Pulication and this application is clearly directed at the aero blades that would be integrated on the side of the car. My observation of this is where would the blades be located on the ME? Looking at the front fender of the ME it doesn't appear there is enough room behind the front wheel well where the blades would logically be located. Hence the blades make more sense on the C8 FE.
Who knows though. There is no obvious sign of this in the ME test car, and not a single sighting of any FE car being tested. It could be for the C8r as it has vents there.
The camouflage wrap is doing its job. You can't decipher anything....
Save The Wave,
Corvette_Nut
Save The Wave,
Corvette_Nut
In that 2nd picture above note the loose edge of the scoop. Perhaps this is part of the active aero to create turbulence for the intake?
What happens when the car is oversteering and the driver corrects, does he lose the downforce because the steering wheel is not pointed towards the apex?
I would think these side blades most likely do not create downforce. Reading the publication, it explains low air pressure aero on one side of the car and high air pressure on the other side to assist in high speed turning. Both sides can swing out also, in effect creating an air brake.
Didn’t the Cien side scoops work the way described ?
