Very odd situation, is this stop/start tech?
I notice when turning my M7 does not allow me to throttle the gas. I press the gas and absolutely nothing is happening.
Been trying to figure out what this is even called but I have no idea. Maybe stop/start technology? I am absolutely baffled by the technology in the car that doesnt give me full control of the throttle with the gas pedal.
Someone please shed some light on this, I even turned on Race mode and it still does the same thing. Although I was not too sure on how to select the sub-mode in Track.. It doesn't confirm that I am in wet/dry/sport1,2/race so I don't know if it's even engaged.
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
The following 3 users liked this post by KenHorse:
That's messed up. You've got a defect on your hands there. Chev. dealer time.
It doesn't happen when taking turns, just when stopped and taking a sharp corner or something. But still sounds like that is very wrong.
It seems like some sort of throttle control to protect you from losing the back end
Received 19,303 Likes
'20-'21-'22-'23-'24
Follow the advice of the others in the thread - have the car checked out by your dealer. It sure does sound like something is wrong.
I will ASAP. I've never used a factory warranty on a vehicle before- do I explain my issue and they are obligated to check it out? Should I just pay the $180 or whatever it is to just run an entire diagnostic?
Bulllitt:
"previous owner".....I had assumed this was a NEW car....as did a few others on here I think.
What year? How many miles?
She's definitely not behaving properly. If you still have the factory warranty...NOTHING should come out of your pocket as far as $ goes to get her looked at and repaired.
My fault then,
2017 Grand Sport 2LT
14,700 miles
delivered from West Palm Beach, FL -> San Diego, CA.
That's very odd, it really seems like some sort of restrictive throttle control because it only occurs when the wheel is tightly turned, im moving slowly (0-3mph) and I try and accelerate while still turning.. Still, it's weird and hopefully it's just some sort of control measure that was never turned off.
Wouldn't the factory warranty transfer over to me? Or can they call an issue because I am the 2nd owner? I dont really see the difference as the first owner could be in the same spot.
14,700 miles
If the previous owner "did something" to invalidate the warranty, the dealer will tell you. Otherwise, they will fix it or, possibly tell you that it is normal.
Just take it to the dealer (even though you seem hesitant to do so for some reason) as anything shared here for such an odd issue is going to be pure speculation.
dvilin (02-16-2019)
No stop/start technology for the Vette... yet! Hopefully never. I agree that a visit to the dealership is required.
There is no control on the car that would cause the condition you are describing. Just as others have stated take it to the dealer and get it repaired. Personally I have never heard of this problem. Are you giving it enough throttle that you can feel the pedal move? Very confusing so as stated visit the sevice dept.
Originally Posted by BullittEV
My fault then,
14,700 miles
14,700 miles
Received 8,928 Likes
You don't say anything about what else is happening with your car when this problem is occurring. Are there any indicators or messages showing up on the Instrument Panel of the Driver Information Center. Do you get a blinking Traction Control indicator?
You do know that all Corvettes will skip the front wheels sideways in very tight low speed turns due to the design of the car. This isn't a problem but a function of designing for performance. Wheel alignment, suspension design and the width/stiffness of the tires are all contributors to the skipping. This is all explained in the Owner's Manual.
When the skipping is happening the stability and traction control systems may inhibit throttle input to prevent loss of control. One test I an suggest that you run so you can know more about what is happening is to go to a large empty parking lot and start driving in a wide circle using the throttle to keep speed up. Then start tightening the circle and gradually spiraling the car toward the center as you maintain throttle opening as constant as possible. At some point the front wheels will start to slide and the car's stability system may start to limit throttle input. The Spring Mountain New Owner's school has similar exercises run on wet pavement that show how the car's stability systems limit slides in emergency situations. Remember the car can only go by what it's sensors tell it so has no idea whether a certain situation is an emergency or not.
If you want to use the Track Sub Modes you have to turn the **** on the center console to Track followed by pressing the ****'s center button twice in succession to get to the sub modes. Once in the Sub Modes you will see the Word Wet displayed in the DIC. You then turn the **** to display what you want on the DIC. Once you see it stop and do something else. Pushing the center button will toss all of your selections out the door. One thing to remember you will still have Stability Control in Wet, Dry and Sport 1 selections with some throttle dampening (how fast the throttle opens/closes). Sport 1 will not have any Traction Control but will still have PTM, Sport 2 will not have stability or traction control but will still have PTM and throttle dampening while Race will only have PTM.
If you want to turn off traction control you can leave the driving mode set to Tour and push the center button of the **** once. You will see the TC indicator on the instrument panel light up with a line crossed through it. If you want to turn off both traction and stability control then push and hold the center button until you see both TC with a line through it and Stability (car outline with squiggly lines with OFF printed under it lit. Then see how your car reacts. However, be careful since dropping the hammer with the steering wheel turned tightly and with TC and Stability Control turned off will loop the car faster than you can imagine.
If you are still getting some throttle limitation with everything turned off then you have a problem with the car.
Bill
