Windshield washer jet not spraying?
Which fuse govern the windshield washer pump? When I pull the stalk I don’t here the normal whirl of a pump.
for that matter, where IS the spray nozzle?
Received 1,620 Likes
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
May not be a fuse, pretty common for the pump to fail. Had mine replaced under warranty with less than 2k miles. If not under warranty I hear it's a pretty inexpensive part ($20) and not too difficult to replace.
Former Moderator
Oh and it’s behind the drivers side fender near firewall.
Received 19,293 Likes
'20-'21-'22-'23-'24
The spray nozzle is at the end of the fat part of the wiper arm - just lift the wiper arm up and follow the rubber hose that goes from the pump to the nozzle.
Ouch!!!!’ 😜
Former Moderator
Is this it?
https://www.amazon.com/ACDelco-22999...dp/B010GKYO78/
According to the parts DB:
https://chevrolet.7zap.com/en/corvet...895852-0-0/#25
PN 22999423 is the number for the pump?
That's an interesting proposition...I would suspect if there's a crack or leak from the reservoir, and the reservoir is dry, that the windshield washer level sensor would trigger a warning light on the dash?
Or is there a windshield washer level sensor present?
Really? It WAS the pump? 2,7xx miles in and 7 months into the ownership?!
I was fixing to get the front stage 3 splitter buttoned down. In my haste to make the video I left the last 2 bolts out on the splitter to make it easy to install the stage 3 extensions, but in reality I didn't need to so I jacked up the car today, put the two bolts back in, and while I'm there...Lifted up the front of the car, remove the driver's side front wheel, peeled back the liner, and popped the new pump I bought last week in.
Fired up the car and pulled the stalk, and lo-and-behold...Jets of water coming out from underneath the wiper arm.
Sigh.
Sigh.
Former Moderator
glad it's working! Mine went out with 1700 miles on it!
