Rate my fuel install
First time doing fuel line work so I'm curious what you think, on if it looks right or not. For the intake side of the fuel rail, I had to use a 90 degree fitting off the FPR as a straight line and 45 degree was hitting the distributor. Surprised TPIS didn't account for that better... I went with the 90 down and then a 45 adapters to get it to go down and then point back out the other side, under the distributor. I went with PTFE line with fragola fittings. Goal was to keep things away from the header, look decent and be functional. This if for my miniram swap.
I have to say nice. They look exactly like the lines I made for my 87. I like the PFTE because they are less bulky than standard . I went with them because I was running E85. Probably not needed but it seemed like a good idea at the time.
Imo, not enough zipties to be considered a "proper" install. (kidding of course, looks mint)
looks awesome. needbto do a ptfe install. where did u get lines and fittings?
Looks good, have you pressure tested it? There is a fitting in the top picture that looks like the line is a little crooked but very possible im just seeing things.
I haven't yet as I ran out of time for the day. Plan to this weekend. I know the section you are talking about (the 90 degree fitting). Their is a little bit of an angle right off of it but it is pretty minimal. It was pretty bad at first so I added the 1 inch extension fitting to reduce the flex. I have another 1 inch extension that I can add if needed. Should I add it before pressure testing to be safe? I wanted to keep the fitting numbers down as much as possible to reduce the risk of leaks. I initially tired a 45 degree fitting their but it was pushing the hose real close to the header, thus the current set-up with the 90 degree.
I got them at Summit Racing. I saw several other vendors but they were MUCH cheaper so I was nervous about quality. Figured with fuel lines I didn't want to take the risk so I went with what I thought was at least quality products. I got 10 feet of line (which was more than I needed) and all the fittings. Spent about $300 but if I didn't have the extra fittings it would have been about $200. I just bought a bunch of extra stuff just in case so I wasn't waiting for parts if things didn't line up well. Figured I'd use the extra's at some point anyway down the road in this car or another.
it looks great, i like the braided hoses. just keep in mind heat makes fuel hot and vapor lock an engine. they appear to be quite close to that valve cover in the one pic but it might just be the pic angle, aside from that awesome
Yeah, one reason for doing this was to get rid of that 30 year old hose that is in the middle of the hard lines there (it was getting old and brittle) and to get it away from my headers. The hard lines only had about a 1/4 inch gap between them and the headers by the number 2 cylinder pipe. The fuel lines at the valve cover is about 3 inches away (at the closest point). I'll double check though. If anyone sees anything else to check, I'm all ears.
Miniram Install and fuel lines looks good, doing mine as soon as I get my heads back from the shop. Can't wait for Winter to be over.....
*$#it happens though. I've seen tpi engines boil the fuel in the rails and have a hard start condition though. When you key off and the line pressure drops then yes. It can happen.
