Fuse
Received 1,116 Likes
The CTSY/LAMP fuse supplies battery voltage to the body control module (BCM). The BCM applies battery voltage to the underhood lamp through the courtesy lamp supply voltage circuit. When the hood is opened, its switch closes providing a ground circuit, and the underhood lamp illuminates.
Should be at the instrument panel BCM fuse box
ramon1367 (02-17-2019)
Vette_DD.
I'm not sure which is more magical: The fact you gave an answer from the OM (which is downloadable for every year. ) or that I can only see the diagram on a reply to your post (not your actual post)?
eta: never mind, I see you edited it and add the diagram.
I had 2 05s, an 06, an 08, and an 012, so several of the ower's manuals were downloaded for myself.
I guess I wasn't clear. While you were editing (minutes? seconds?), when I was replying, and I could see the diagram, but not in your original post. It was odd, to say the least. That coupled with a RTFM (implication ), I guess, my humor was lost in there.
Not everyone gets my sense of humor
