What is a good cleaner to use on black plastic dash panels?
Would like to clean up my black dash panels. Do not want to have the top of the dash to glare in the sun by using some cleaner or polish that will make it shiny and a nuisance when driving in the sun. Have heard horror stories about ArmorAll and want to stear clear of that.
What would you recommend that will improve the looks of a 20 year old plastic dash surface but not destroy it or make it a shiny mess?
Received 1,679 Likes
Mild soap and water using a microfibre towel.
Edmund Iverson (02-06-2020)
Received 3,812 Likes
St. Jude Donor '03-'04
I agree.. mist of soapy water, or just water.. some soaps are acid anhydrides, some soaps are basic anhydrides.. the test of an acidic soap is to liquify it , put it in the palm of your hand and squeeze, if you can feel heat its an acid.. not use that soap on your plastic dash or any plastic products. There are soaps used to strip the wax off a car, and others to clean the surface. without touching the wax.
An example of a PH neutral soap is Chemical guys Citrus extreme suds. will not strip waxes or sealants. You want something that is PH 7 or higher, anything below a 7 is acidic.
Bill aka ET
Bill aka ET
Received 2,706 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
This stuff works wonders on all plastics, interior or exterior...
https://www.jpcycles.com/product/900...waAmRNEALw_wcB
I personally don't use anything on my dash or steering wheel airbag (many horror stories on the forum about sticky airbags, the 98 I purchased had that problem). Therefore, I'm with the others. Water and microfiber towels. I imagine a little bit of car wash soap might be okay as it should not strip wax (per Evil Twin specs) but use nothing like Dawn which will strip wax.
That place is real close to where I live now. My old neighbor works there.
El original (02-21-2019)
Damp microfiber towels are all I use. Soak a few, wring out, and wipe. For all the stuff that’s hard plastic and small like HVAC vents and change overs from one piece to the other I dig in with cotton swabs. Everything gets a final going over with a shop vac.
I don’t like my all black C5’s interior to be glossy and I feel glossing it up gives it a bit of a faux appearance. My opinion of course. Plus over time with just using wet microfibers everything takes on a more subduded “lived” look.
I personally wouldn't use it on a dash of my corvette, I'm a damp towel kind of guy. But for my DD's, only thing I use for interior and exterior because it's just too easy!
https://www.walmart.com/ip/Meguiar-s...0wipes&veh=sem
Wizard makes a good product i use on my interior...
The answer can be found right in your Corvette owners manual.. Water and a clean cloth.
Bill aka ET
I know a few things because I have seen a few things.
Jim_ZO6 (02-20-2019)
Appreciate the response ET.
I must admit I've always been under the impression that protectants were a must, but it does not appear to be the case just based on the chemical characteristic of the plastic used in dashes.
My guess is that cracked dashes are just a result of design flaws and inevitable deterioration of the UV stability of the plastics used in some plastics.
Sounds like it pays off to park in the shade!
303 Protectant a clean sheen that give you UV protection spf 40. A must here in Florida, all rubber, plastic and vinyl surfaces. It's not greasy and has a satin sheen which looks fine. 303 Great products.
