[C2] Information
Good luck.
There are gross numbers for individual options, but when you ask about combinations of options the math breaks down because there are no records of that data...
67 Info
Currently the car has a 350 but the tach shows 6500 and oil show 80 lbs. It was born on April 19, white, std black interior, 4sp., PW,PB and that is all I know so far. The car was set up for road racing with front and rear flares, runs 255-50-r15 tires and has a single hoop roll bar, regular gas tank., On the 350 is a complete l-88 air cleaner setup plus the hood holds the air filter
There were only 35 cars with heater/defroster delete for 1967. I assume 20 of those were the L88 cars. That leaves 15 remaining.
There was no radio delete. Radio was an option, so no radio simply meant that you did not order that option. There were 747 cars that year (out of a total of 22,940 produced) that were ordered without a radio.
Obviously car was bought to be a racer of some sort.
Larry
Larry
Received 6,937 Likes
2015 C2 of Year Finalist
Larry
Larry
Larry
Larry
I should have looked at Noland's Book first, but instead I relied on a listing I have of various options and deletes in my files. This listing was incomplete.
Larry
EDIT: To the OP, look at Noland's Book on C2 Corvettes, page 404 for the breakdown by model and engine
not really it could have started out in a warm place. And then sometime later it could have been turned into a race car. Getting a shipping report would settle that real quick. If the car was sold new in Wisconsin you know I’m wrong
I won't argue with you on this, since it is not important to the OP request. However, even in the deep south (where I have lived most of my life) you cannot drive a car in the rain (whether hot or cold outside) without a defroster and a heater to warm the air. ...unless car is air conditioned. And this car is not. The windows will fog up in a heartbeat and you cannot see the road.
That is fact............give it a try sometime when you can. No heat and no defrost and no AC and no cabin air movement.........windows up to prevent rain from getting in the car............temps can be warm or cold, doesn't matter.
Larry
I understand that. That’s why it became standard for the 68 model year that all cars and trucks have a heater
