Trying to make a racing seat more comfortable on a long drive
Hello guys,
I am looking to go to Road America in September this year. I live close to montreal, so we are talking about a 16 hour drive to there. I do not have a truck, so it will be done with my car.
I have installed a OMP FIRST-R Racing seat in my car. In general, it is very comfortable and I love it (so much that I miss the side support when I get in other cars), but after about 3 hours, I start to develop pretty bad pain in the back of my thigh close to the knees, and in the rear of my *** (but not in my back). I tried to remove the front cushion while the pain was there, but I didn't see much of a difference. I am 6'2" 240lb if that matters.
I have tried to look at various ergonomic resources, but they mostly talk about the driving position, not seat improvements.
I would like to know if you guys have any tips to help on this. I thought about buying a memory foam cushion and put it on the seat, but instead of wasting money on trial and errors, I figured I could ask here first.
Hey, what is your setup in terms of seat base mount and side mounts? Any sliders?
I'd guess adding some lumbar support and not having too much of a rake (which puts pressure on the back of the hamstrings) would help this.
I was looking to buy longer bolts and washers this year to fix that.
I used to do 12 hours in my Sparco Pro 2000 with it hard mounted on the floor (similar mount to a Marrad). I gave that up after the AC compressor gave out with 3 hours to go on the way to Lincoln, NE in 95+ degree weather.
That said, the best thing for me was the nice comfortable seat, and just keep moving my legs around. Cruise control helped significantly, along with being able to lay back in the seat and relax somewhat.
a) Put the stock seat in for the drive and install race seat at track
b) Accept the fact that 1 track day will be in OEM seat
c) After spine surgery I used patio furniture cushions to make my truck comfortable and take pressure off the hardware.
d) Buy foam from a cloth/hobby store, mold it to your ***, then cover with a crappy $20 seat cover so it stays in place
It depends if angle or firmness is the primary issue what the right fix is.
Mine keeps my legs quite in check. Barely enough space for the manhood.
2023 Corvette of the Year Finalist - Unmodified
2022 C6 of the Year Winner - Unmodified
oooff...hope nothing breaks on the car. Frankly, it took me one flatbed ride home from Mosport about 25yrs ago to decide I needed to tow. It makes things so much easier and mindless. For about 5 of those years I rented a U-Haul trailer (improvised loading) and towed with a 180hp Toyota 4Runner...lol
Now, while I have my own aluminum trailer and tow vehicle, frankly, I do so few track days that I should probably just rent a pick-up 3 x year from Enterprise.
Anyway, over the years, I've had at least 3 situations where I needed to tow back because the car wouldn't have been driveable, or tire problem, blah blah. Anyhow, good luck and enjoy...I love Road America and always wanted to try it in a fast car
I went with the 1" and 2" version of this (https://purple.com/seatcushions) and use them both driving the car on the street with ultra shield aluminum seats.
I am trying to visit at least one new track each year. Most of the stuff happen at nearby tracks, and once a year, I will go to one that is farther away,
I've made the trek from the Detroit area to Calabogie a few times (~10.5 hours). It's much nicer in a truck with a trailer... That being said, the key is to change your seating position. I've used carpet pad and towels of different sizes to change up the seating position. Carpet pad is cheap, easy to cut and stack behind your lower back or under your rear to effectively change the seating angle. Towels can be folded to do the same thing and they are cooler/breathable in warm weather.
I bought a 6-inch thick piece of the densest foam available from a foam shop and stuck it in a pillow case as a seat cushion. Not only does it help with comfort, but it gets my seating position high enough so it is close to stock.
Rent a truck and trailer.
