Stage 3 splitter choice
Old 02-20-2019, 01:47 PM
Vette Ski
Vette Ski's Avatar
Received 1,076 Likes on 694 Posts
Default Stage 3 splitter choice
Hello,
I am looking to purchase the stage 3 front lip splitter and winglets in carbon flash for my black '19 G.S, Looked on E-Bay. Is the ABS plastic the material of choice. Is there anyone who did this mod that can either P.M me or post here if they were satisfied with their choice, which product to choose or which to shy away from, etc..
How do the winglets attach to the fender ?
Thank you in advance !
Rich K ( Vette Ski )
Old 02-20-2019, 02:48 PM
sTz
sTz's Avatar
Received 2,423 Likes on 1,597 Posts
I went w/ACS for my Z06. Happy with the fit and finish.
Vette Ski (02-21-2019)
Old 02-20-2019, 03:02 PM
96GS#007
96GS#007's Avatar
Received 1,742 Likes on 1,050 Posts
C7Carbon is who I used. If you're doing this for looks, then Ebay is probably fine although it seems the ease of installation is hit or miss. If you intend to use the car on the race track and want full functionality then you need to go with someone who's splitter allows you to install the factory Stage 2/3 undertray. C7Carbon, ACS, and Katech come to mind. I'm not aware of any sub $600 splitters that are manufactured for the tray. In the below photo of my car you can see the undertray and if you look close you can see that it's also molded to duct air to the performance brake ducts that are mounted on the lower a-arms.
Old 02-20-2019, 10:19 PM
ZO6 cracker
ZO6 cracker's Avatar
Can you explain a little about this front splitter with the tray. I thought about going this way. Are any of the factory screws used or is this all rivited on. I see the back parts uses the factory screws. Also I’m looking at this on my phone and a little hard to tell. It looks screwed on. Thanks.
Old 02-21-2019, 12:17 AM
96GS#007
96GS#007's Avatar
It's a factory (OEM) Stage 2/3 tray and it uses factory attaching hardware which are screws. There were a couple areas where I felt the factory spacing could have been better so I did add a couple plastic push pins after the fact. Probably could have done without, but it was a 5 minute exercise so no big deal.
The splitter itself is also attached using the factory bolts and 10 rivets, all of which is hidden under the tray. As an aside, the rivets from GM are something like $6 each. You can buy a box of 25 from ClipsandFasteners. com for $15 and they are identical to the OEM rivets.
There are three differences from the OEM splitter...
1) The winglets use bolts with nuts and washers on the backside to attach to the splitter ends. The factory splitter has threaded receivers molded into it that the winglets (Stage 2 or 3) bolt to
2) The factory Stage 2 winglets have recesses for the bolt heads...although I've heard that wasn't always true and it depended on which vendor was supplying the parts to any given car.
3) The OEM splitter is all carbon fiber. The aftermarket units are fiberglass or fiberglass with a carbon fiber top ply. This is why the aftermarket "carbon fiber" parts are so much cheaper. Some of the really low cost parts are essentially ABS plastic. This is one case where you truly get what you pay for.
The following 2 users liked this post by 96GS#007:
Vette Ski (02-21-2019), ZO6 cracker (02-21-2019)
Old 02-21-2019, 12:28 AM
Matthewstorm
Matthewstorm's Avatar
Why did you bother with the undertray? Makes it much more expensive.
Old 02-21-2019, 01:14 AM
96GS#007
96GS#007's Avatar
Race track. I did this for functionality not looks. The tray affects downforce and brake cooling. At 150+ lap after lap that becomes important.
Old 02-21-2019, 08:45 PM
L82Brake
L82Brake's Avatar
Originally Posted by Vette Ski
Hello,
https://www.c7carbon.com/2014-c7-cor...9bea1d21ab50e4
https://www.c7carbon.com/2014-corvet...9bea1d21ab50e4
I did just the C7 stage 2 and added an OEM undertray ($130 for tray and $25 for screws).
Vette Ski (02-22-2019)
Old 02-22-2019, 12:11 AM
Matthewstorm
Does C7 Carbon have the undertray?
Old 02-22-2019, 09:47 AM
Vette Ski
Vette Ski's Avatar
The stage 2 comes withe the small wing lets
They do look nice.
Thank you,
Rich
Old 02-23-2019, 08:41 AM
L82Brake
L82Brake's Avatar
No, there is another manufacturer, I cant recall who, that offers a set up with the undertray.
I ordered my undertray from a local chev dealer who was nice enough to discount it a little off list. Buying on-line makes no sense due to shipping costs. I found a local fastener company that sells GM fasteners. The dealer wanted like $6 a screw.
Old 02-23-2019, 08:59 AM
Vette Ski
Vette Ski's Avatar
I think the other company is A C S
Old 02-23-2019, 07:36 PM
96GS#007
96GS#007's Avatar
ACS (who also sells a splitter with an integrated under tray), Katech, and GM dealers. I bought mine from Trunk Monkey. Shipping was something like $20, I guess due to the account type they have. The splitter was $130.
Old 02-23-2019, 11:12 PM
Matthewstorm
Trunk Monkey? I find nothing on the web with that name.
Old 02-24-2019, 12:09 AM
96GS#007
96GS#007's Avatar
Top of the heap in Google https://www.trunkmonkeyparts.com/
To Stage 3 splitter choice
Quick Reply: Stage 3 splitter choice
