Anyone have a Z51 spoiler template? Dealer wants three hours labor
Anyone have a Z51 Spoiler Template they want to part with? I stopped by dealer today to ask how much they would charge to install an after market spoiler that uses the Z51 hole pattern. They said three hours labor. I think that is insane. It is just twenty or so bolts and screws holding it on. I don't mind paying for labor but I think this is twice the amount of time it would take. They have over fifty Corvettes in stock with spoilers so it is not like they never did it before. Looks pretty straight forward so I will install myself.
Former Vendor
jimmie jam (02-20-2019)
Former Vendor
Tim thanks for the response. I realize the bumper needs to be pulled back to attach the spoiler. Not trying to start an argument but there is no way it takes a professional technician three hours to do this. There are multiple videos on line showing a technician taking less than a half hour to remove the rear bumper.
Former Vendor
jsieczkos (03-01-2019)
It took me about 3 1/2 hours to install mine. 9 holes to be drilled. But like TimBoone said in the previous post, I spent a lot of time making sure the template was lined up correctly! Unfortunately I had that template that came with my OEM spoiler in my hand holding it over the garbage can in the garage scratching my head thinking should I save this or not? I decided not to save it and dropped it in the can.
Received 19,305 Likes
'20-'21-'22-'23-'24
Exactly. That’s how fast and efficient mechanics can make good money. Bill by book hours but actually do it much quicker and move to the next task and do the same thing. Bill 80 book hours a week but actually do the jobs in 40.
fsvoboda (02-21-2019)
SoCal Events Coordinator
St. Jude Donor '12
Dealers and pretty much all mechanics charge by the flat rate manual not by how much time it actually takes them. Its been this way for 50 plus years. Either do it yourself or pay up.
If I remember correctly you can access the end spoiler nuts through the tail light openings with the bezels removed. So if you wanted to cut corners and not want to pull the bumper cover off you could probably just install two sided 3M tape in the center and drill the end holes and attach the nuts through the tail light openings.
Shouldn't be anymore then an 1.5 labor hours, the worst part is making sure the template lines up correctly.
See this on you tube-How to install a spoiler on a corvette in under 20 minutes. works on any C7 2014-2019 from the Chevy Dude.
For the template, ask some of our vendors - RPI, EOS, ACS, SCP. Might be cheaper (free?).
