Battery Type - 2019 C7 - 1LT
Picking up a new 2019 C7 1LT tomorrow. Thinking about picking up a battery maintainer for it but not sure if it the OEM battery is a wet, gel, or AGM type. I think my 2015 C7 had a wet type battery but am not sure. I know a lot of vehicle brands are putting AGM batteries in from the factory if the battery is located in the passenger compartment to reduce the chance of fume problems. For example, my 2018 Jeep Grand Cherokee's battery is under the front passenger seat and is an AGM. I called the Chevrolet dealer parts department and they did not know. The parts guy put me on hold and asked a service advisor. He was not sure. They said they had to check with the service director and I was supposed to get a call back hours ago. Thought I would ask here on the forum.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,820 Likes
2015 C7 of the Year Finalist
Doesn't matter. Get the C-Tek and it'll cover you just fine.
There are cheaper models, but this is the one I have.
I used it on the OEM battery and I'm using it on the AGM battery that is currently in my car.
Elmer
Elmer
The OEM is regular (not AGM) and as Elmer mentions, the C-Tek works just fine.
Doesn't matter. Get the C-Tek and it'll cover you just fine. There are cheaper models, but this is the one I have. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I used it on the OEM battery and I'm using it on the AGM battery that is currently in my car. Elmer
Elmer
Also buy the CTEK 56-263 Comfort Connect Plug so that you can plug it into the 12 volt receptacle in the passenger side rear corner area of the cargo area that is there for the battery charger. The CTEK 56-263 Comfort Connect Cig Plug costs about 10 bucks.
