Random Misfire
Random Misfire
Just wanted to share this with my fellow corvette owners now that I have finally figured out what was triggering a random misfire code in my 2012 Grandsport.
Here is the short version of the story -- Had a random misfire code and a flashing MIL whenever I accelerated. when I came to a stop the MIL would go off. Engine RPMs at idle remained constant and seemed to have no loss in power. When placed on a scope, it seemed like all 8 cylinders were registering a misfire. Did a load compression check and everything checked out fine. Swapped plugs, coil packs and a had a ECU loaned to me -- still the same. I was stumped and about ready to put a piece of tape over the MIL when I stumbled onto the root cause of the issue by accident....
My torque tube had about 4 inches of play on the back end. Basically what I could determine it was failing and causing a vibration which was triggering my knock sensor. Once I replace the torque tube … no more issue. I would have never guessed that this would have been the root cause of all my issues. sometimes it is better to be lucky than good...lol
The following 6 users liked this post by C6topless:
kperez (02-22-2019),
Landru (02-22-2019),
ontime (02-22-2019),
TCW (02-22-2019),
Vet Interested (02-23-2019),
and 1 others liked this post.
Hi C6topless
thx for that. I've been having an issue for 2 years now. Tried lots of stuf ( MAP sensor, spark plugs, etc)... As soon as snow is melted, i will definetly try that one. I'm not sure where and what the tube looks like, but i still have time to check it out.
Hope that helps my issue too. I will let you know.
Thx
Marc
Thx
Marc
