FS: C3 NOS, used, re-plated, and new parts, many BB, some C2
NEW, LOWERED SUMMER PRICES!
NOS, used, re-plated, and new parts left over from years of collecting and restoration. Many 68-72 BB parts. PM me items you are interested in along with your zip code and I'll send shipping quote. Make offer on multiple items - I want this stuff gone!
NOS GM Factory 70 71 72 front right fender fiberglass, rear half of fender - $125
NOS 1970 1971 Corvette w/ AC relay 1115981, not sure if its correct for other years - $25
Parts lot - new gas pedal & trim, used windshield corner chrome trim, used maker bezel, fiber optics lens & grommets, new T-top hold down cleats, screw to attach front grilles - $5
Used coil bracket and re-plated original mounting screws - $10
NOS GM 1968-82 5638317 wiper - headlight door override vacuum valve - $30
New Corvette starter drive - $10
NOS Front Seat Track Adjuster **** Chrome 1965-1977 Also used for 1964-1967 Corvette Seat Adjuster **** Chrome 3846934- $30
NOS pair of 1968-77 Guide pins GM 3956392. Not sure if these are for T-tops, convertible, or both. - $50 for the pair
NOS OEM GM 1968-77 Corvette Inside Door Handle Right Hand 3962694 - $75
NOS Corvette T-Top Spade, 1968-1982 - $30
Re-plated original set of washers and tubes from sway bar off of '70 Vette with LS5 & AC - $10 - SOLD
Re-plated original and new front end shims and one new SS rear end shim, 11 pieces total - $10 - SOLD
3 Used front bumper shims - $5
3 Used 70 BB radiator support to front cross member large shims - $25
Used chrome air cleaner lid from '70 BB, pitted, still has the stencil on backside - $10
NOS '70 LS5 engine label that mounts to console, 3976372 - $30
NOS 69-72 LS5 BB Corvette w/AC windshield washer bag 3961549 - $65
Used overflow hose (radiator to overflow tank) and original clamp from '70 vette LS5 with AC - $50
Used 5044760 heater and AC blower motor, fan, and rubber tube, runs very smooth - date coded for '75 but could be used on other years - $15
Used original molded heater hose from '70 with BB and AC, comes with the original Wittek Suretite # 12 hose clamp - $15
Re-plated gas tank neck bolts from '70 (9) - $15
New Turbo 400 modulator valve - $70
(5) original, restored bolts for overflow tank brackets and mounting bracket from 70BB with AC - $30
Original re-plated and used slightly (7), and (10) new 69-82 body mount shims, and (1) original re-plated nut for body mount - $15 - SOLD
Two used horn button assemblies - $8 each
Corvette Water Leak and Wind Noise Solutions - $70 - SOLD
Original Corvette 68 to 82 restorers guide (hardcover) - $15
Corvette ID numbers '53 - '93 - $5
NOS C3 Corvette AC valve controller 69 70 71 72 73 74 75 76 Delco 7309782 (fits GTO as well) - $60
Used C3 Corvette Power Window motor and coil spring from '70 vette - works but moves slowly, right side, use as a core. Comes with an NOS box, $10
NOS 1846657 alternator rotor for BB car - $50
New frame stencil template for '70 car, 4/1/70 date - $5
1970 Chevrolet Accessories booklet - $8
1970 Vette Dealer Brochure - $12
1970 'Chevrolet On the Move' album, Glenn Campbell, Dionne Warwick, Burt Bacharach - $15
1970 Chevrolet Custom Accessories guide (crusty) - $5
1970 Chassis Overhaul Manual (covers 1969 Vette) - $20
Lots of other Chevrolet (mostly vette, Chevelle/Monte) and Buick GS/Skylark literature
1990 Vette ZR-1 bright red promo car - $10
1970 Corvette NEW Big Block BB Engine Emissions Vacuum Hose Kit 390HP - $5
Re-plated overflow tank bracket and mounting bolts for LS5 with AC
Last edited by 1970greenLS5; 06-25-2019 at 06:47 PM. Reason: LOWERED PRICES FURTHER IN JUNE / MARKING SOLD ITEMS
Interested in the headlight check valve and filter assuming they have the correct markings.
43016
And I got tired just thinking about how long it took to put that ad together.
43016
I am interested in the 5 port if its a known good working unit (seals not dried out), the THM400 modulator as well as the saddle under steering column cover 10598
Sorry the console covers went right away last night. Door pulls can go in flat rate box $7.90 for total of $27.90. Please confirm want them and send me your address via PM. I would take check or Paypal. Steve
Cabman2 - message above for door pulls was to you.
Barry - not sure what the correct markings should be. I don't see anything on the filter, but the check valve has lots of markings including Trico label and part numbers. Pix attached. Both of those would fit in 2 day priority flat rate box - $7.90 for total of $82.90. And yes, it took a long time to put that ad together! Way more time than I thought it would...
ThumpingLotus7 - I don't know if the pump works. This is exactly how I bought it. That and the modulator are still available. The under column steering cover went last night via PM. $14.35 for shipping in flat rate box, total is $214.35 for 5 port pump and modulator.
dklumpp - someone PM'd last night on the assembly manual and Doc Rebuild drawings. The other items are all still available. Water and Wind Leak Repair, Fact Book, Original Corvette 68 to 82 restorers guide, and Corvette Book of Numbers, plus some look copies of wiring diagrams I found would be $135. I would add dealer brochure for $15 for total of $150. Shipping would be $14.35.
Pmccooey - shipping is $5.
All, please PM me with your mailing address. I will take check or Paypal. thanks!
2017 C3 of the Year Finalist
St. Jude Donor '20- '21
Would you sell the 1970 promo for $15 only and I will take the Fact book as well,. Will probably add a few more thanks Ike
Edit the 1970s literature and manuals if available. Thanks Zip is 11234
Ike - dklumpp was first in line on the literature. I'm still waiting to hear back from him on whether or not he wants the literature including fact book . If not, its yours. I'll reply to your PM on the promo's.
marshal135 (07-23-2020)
Hello Ike. I did not hear back from dklumpp, so yes the fact book is still available. I've marked it and the promo's as sold for you.
I didn't get your email reply. Feel free to call (think I put my cell number in the email?) or contact me via PM to finalize what other parts you want. Steve
Hello,
Interested in
Parts lot - new and used ac parts for 68-72: soft lines, valves, Harrison sticker, hard lines thru radiator, AC pulley, resistor, hose clamps, and valve clamps
New '69 - 72 Corvette AC condenser, couple marks from storage - $125
if they are still available. What would shipping be to 29579.
Thank you
Interested in
Thank you
Hello Raven. I tried USPS and UPS shipping calculators to see which was cheapest. It turns out its less expensive (and probably safer) to ship in two separate packages via USPS. The AC condenser would be $39.57 to ship. And the AC parts lot shipping with USPS is $32.49. Someone else PM'd me about the condenser after your post. You have the first option to buy it as you were first in line. Let me know one way or the other. thanks, Steve
I have not heard back from the people that were interested in AC parts. So all the AC parts, including the condenser, are still available. I've added a few more items to the list of parts at the top of this post.
Thank you
Did you sell the 5 port washer pump to Thumping Lotus? I’m interested in the pump if it’s still available. I know sometimes these items are
sold under pm messages - did not see anything else on the pump and it is not marked sold.
Thanks and Respectfully,
Tugboat53
Tugboat53
