Front lift system
Front lift system
IF this car comes out someday hopefully they incorporate a front end lift system like other high end cars, I was all good on my 16 Z06 till i added the stage 3 splitter with the winglets, Then i had to build a removable ramp at the end of my driveway as i couldnt get onto the street without ripping off my new splitter
Hopefully this is an option.
The following 2 users liked this post by ajgoyt:
firstvettesoon (03-10-2019),
SLOjoe (03-13-2019)
Our best belief that a FALS is at least an option on some models of the ME based on this CAD drawing, e.g., the hydraulic line coming from the bottom/side of the coil/shock tower.
The following 4 users liked this post by elegant:
ArmchairArchitect (03-18-2019),
LB001 (03-18-2019),
Mikec7z (03-09-2019)
E-Ray, 3LZ, ZER, LIFT
Received 9,605 Likes
Side Bar
May be of interest to add a "splitter protector" to your C7 Stage 3 splitter. Although the Stage 3 winglets aren't the issue (I replaced my Stage 2 winglets with those) I added a "protector" to my Stage 2 Splitter option. It has saved my carbon fiber splitter several times. Yep you can fix your driveway but like me, you could get caught in a parking lot exit that is steep. Here are some pics and my install PDF: http://netwelding.com/Splitter_Protectors.pdf
Pic of splitter protector installed
Splitter protector, made from slippery plastic that protrudes ~3/16 inches and takes the scraping with no damage to the carbon fiber splitter
ACCHRM (03-17-2019)
The other accessories are easy to ID:
Top left: Water Pump
Bottom left: Alternator
Top right: Mystery accessory, circled in orange
Bottom right: AC compressor
When you scrape yours you'll be upset and wish you added a protector! And you will! But to each their own!
One reason I wanted carbon fiber is it is strong and can flex somewhat without cracking or breaking. Same with my OEM Carbon Fiber side skirts. Hit those in my 2014 with no problem. So far neither I nor a passenger hit them in the Grand Sport in 2 years. But someone will!
I know guys with those cars and I still poke fun at them just the same for it, dont worry haha.
The front bumpers do have a bunch of give when you smack them underneath, it is just a funny solution.
I looked at several options as mentioned I hit the CF splitter I put on the 2014 several times. Including a cheap one I added. These were cone washers that it was said NASCAR was using. Perhaps but I could see them getting caught if I backed up after riding over a concrete wheel stop etc.
Decided the Scrape Armor product I added was far better. It was far more expensive as well! But the material feels as slippery as Teflon! So far it has saved me getting a new carbon fiber splitter twice or perhaps needing a repair of a very rough and perhaps cracked lower edge. Was told they have several auto manufacturers adding their product, perhaps as a dealer installed option. These are and easy install.
Porsche offers a Front Axle Lift system on some of their cars...expensive, heavy, and when it fails it’s a $10k bill.
No thanks, been driving Z06s for 15 years and never a problem with clearance that couldn’t be avoided.
CliffB-99 (03-24-2019)
That line from the shock may be an external hydraulic reservoir for extra fluid capacity. I don't need/want a hydraulic lift system. One more thing to fail/service.
Sounds a bit strange at first but look at the companies website, they sell them for Ferrari, Lamborghini, etc etc! Yep it's 3/16 inch lower but a very slippery material. I had added a carbon fiber splitter to my 2014 and when I scraped the bottom edge it was ragged and looked like hell. Hard to fix. Have to be n ant to see where my splitter protector scraped the carbon fiber was not touched.
i bet it helps at the drag strip... if the nose is already up a bit, its easier for the back wheels to catch and bring the nose up even further. Then the car can be lowered back down a moment later as its completing its run.
The Front Lift System was confirmed earlier today on C8 general forum by the deleted screen shots and thread provided by a member here.
..Progress is being made on how the C8, is equipped/optioned, albeit prematurely.
