C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] What is considered low oil pressure??
Old 03-21-2019, 10:45 PM
Amendoza
3rd Gear
Amendoza's Avatar
Default What is considered low oil pressure??
Looking at pulling the trigger on this 2006 c6 z06 as I was test driving seemed to me to have low oil pressure??
Its has a rpm head/Cam package. Should I stay away or is this normal. Car has 44k miles...
Here is idle pressure vs 3k rpm pressure
Old 03-21-2019, 11:29 PM
SPDKLZ1
SPDKLZ1's Avatar
Normal if up to temp. Mine has been 24 with oil at 200 degrees and 20 at 215 for a few years. It was the same prior to heads/cam a couple years ago. Runs strong and uses minimal oil between changes.
Old 03-21-2019, 11:41 PM
truth.b
truth.b's Avatar
To me it seems a bit strange that on a cold startup the oli pressure is so low. On my LS3 drysump GS with cold startups I see 80PSI then when the engine warms up I see roughly high 30 to 40 PSI at idle then 50-60 PSI under normal driving. I only see 30 PSI or lower when I'm at the track and at the end of a long session (30 mins) and the engine temp is usually 225*F or more.
BTW I run 5W-30, the low pressure could be due to oil weight.
Old 03-22-2019, 12:50 AM
Amendoza
3rd Gear
Amendoza's Avatar
What kind of Milage is on your z06 if you dont mind me asking?
Old 03-22-2019, 07:34 AM
Undy
Undy's Avatar
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,095 Likes on 578 Posts
At the water temp showing on your gauge I'd consider that low oil pressure, low enough that I'd walk on the purchase.
airbrush1 (10-31-2022)
Old 03-22-2019, 09:52 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
While it does meet factory spec, it does seem low. All my motors have seen 70+ at idle when cold, and drop to that when hot, like 200+ water/oil temps. I would be weary.
Old 03-22-2019, 10:51 AM
SPDKLZ1
SPDKLZ1's Avatar
15K, same oil pressures when I got it in stock form at 3k.
Old 03-22-2019, 10:55 AM
MTBSully
MTBSully's Avatar
Hard to say if its not hot.
Movie Muscle (10-30-2022)
Old 03-22-2019, 11:45 AM
NemeZ
NemeZ's Avatar
After I did my heads and cam that’s what mine was at. It has slowly decreased over time. At 190f my oil pressure gets as low as 17 psi. Not good. I would walk away if I were you. Currently at 61k miles.
Old 03-22-2019, 11:56 AM
Z0HM6
Z0HM6's Avatar
On a cold start, my pressure is around 70-80 psi and drops to 30 when hot
Old 03-22-2019, 12:44 PM
73DBG
73DBG's Avatar
Same as most these guys posting....cold start is always 50psi+ prob more like 60’s. 200+ I see 25psi at idle and that’s normal on mine. I’d also be concerned at that psi on a cold start or just warm(psi @ sub 150 deg) is probably pass without knowing more....unfortunately only way to get those answers would be very intrusive to the motor, something that’s not gonna be possible on a car you don’t own.
Old 03-22-2019, 12:54 PM
Mr. Jean
Mr. Jean's Avatar
Mine is a 09Z06 with about 28K and on cold starts it's at 70-75. When looking at your gauges I'd say it's lower than I'd like. I don't go to 3K until it's warmed up more either.
See if the owner can get it warmed up to at least 180* and look at it again. It's going to be less obviously, but how much?
Myself, I'd probably pass on that one. Good luck.
Edit: What's going on with the voltage in the second shot? Why way low?
Old 03-22-2019, 04:08 PM
Too-Fast
Too-Fast's Avatar
It's too low at the temps shown on the gauge in both pics.
Old 03-22-2019, 04:40 PM
The
The's Avatar
I was thinking the same. I have the same heads cam package (RPM) and experience much higher pressure. 16,000 miles on my car. 5k with h/c.
Old 03-22-2019, 05:19 PM
03Zcrit
03Zcrit's Avatar
CEL is on too and with everyone above. Cold start even with ambient in the 90’s sees above 50 PSI.
Old 03-22-2019, 05:30 PM
truth.b
truth.b's Avatar
FYI: My C6 GS is a 2013 manual with 122K miles and sees the track roughly 3-5 times a year. Only changes are Attack Blue Filter and 1-7/8 TRI-Y Headers with a good tune.
Old 03-22-2019, 10:36 PM
KurtsZ06
KurtsZ06's Avatar
Same as mine. My pressure doesn’t drop until water temp indicates hot. Low pressure when cold is the oil pump, my experience twice with cars in the past. Could also be as simple as a faulty sender unit, but I wouldn’t bet on it.
trying to sell a car with CEL on, good luck.
To What is considered low oil pressure??
Old 03-23-2019, 03:13 AM
Movie Muscle
Movie Muscle's Avatar
That pressure is low for the engine temp and what will also be an even lower oil temp. Based on both the LS7's I've had. Pressures were about 70psi cold. Also the 2006 Z has the oil to air cooler which requires a long time for the oil to reach proper operating temp. Coolant/engine will be at temp for quite a while until oil numbers are at temp. If looking at other cars check not just your engine temps to discern pressure also scroll through the information center to find your oil temp. I would walk from this one.
Old 03-24-2019, 07:42 PM
ttx350z
ttx350z's Avatar
68K on min. Cammed for the past 25k miles. Sits at 31 PSI when oil temp is 170+ F. Cold oil is around 70 PSI.
Old 03-25-2019, 07:12 AM
68birdls1
68birdls1's Avatar
Pretty sure the rule is 10psi per 1000 rpm
Quick Reply: [Z06] What is considered low oil pressure??
